RobertR70
#1 Posted : Friday, April 6, 2012 4:40:10 PM(UTC)
RobertR70
I have A GE JUNK REFRIG. I HAVE A FREEZER THAT KEEPS FREEZING UP I HAVE PUT A NEW CONTROL BOARD ON IT FREEZE UP I'VE CHECK THE DEFROST HEATER I'VE CHECK THE DEFROST THERMOSTAT ITS GOOD AND YES WITH A MULTIMETER THERE IS A THERMISTOR NEXT TO THE DEFROST THERMOSTAT COULD THIS BE THE PROBLUM OR COULD THE NEW CONTROL BOARD BE BAD:confused:
#2 Posted : Saturday, April 7, 2012 7:26:19 AM(UTC)
With the fridg running, unplug it, and locate the 3 pin gray power connector on the bottom of the motherboard. Remove it and place a wire jumper between the two pins that mate with the board labeled pins line and def. Plug in fridg, it should start defrosting. If not, you have either a bad heater or defrost thermostat.
RobertR70
#3 Posted : Thursday, April 12, 2012 2:06:28 PM(UTC)
RobertR70
:confused:
I got your your reply to my question but I am not clear on what to do. I no where the plug is you are talking about The line -Def & Comp Pins Now what I need to now is do I jump the Line pin & Def pin on the board and plug and plug conector back on the control board . Or leave plug off control board with jumper in it to test. Now if it does work and I connect it back to the board and it does the samething could the sensor be the problum.
#4 Posted : Thursday, April 12, 2012 3:37:13 PM(UTC)
You do not plug it in the board,just plug fridg in, if there is no defrost action, you have a heater or defrost thermostat problem.
Robert Shaw Fireplace Gas Valve - Sticks (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 11/15/2023 4:04:14 PM(UTC)
can I replace my DCS igniter (211541) with Robert Shaw replacement? (Oven Repair (including Ranges and Cooktops))
by joeb2 2/24/2019 4:16:29 AM(UTC)
robert mikolay (Refrigerator & Freezer Repair)
by Robert Mikolay 10/31/2016 10:31:50 AM(UTC)
Robert (Refrigerator & Freezer Repair)
by rawhitman1@aol.com 2/12/2013 4:15:26 PM(UTC)
need wiring diagram for magic chef furnace and ac unit with robertshaw gas valve and (Heating, Ventilation, and Air Conditioning (HVAC))
by bigdaddy88 8/2/2012 4:16:30 PM(UTC)
Robert (Washer Repair)
by DALRO 5/1/2012 2:33:49 PM(UTC)
Robert R. (Washer Repair)
by Robert R. 5/14/2011 3:47:52 PM(UTC)
robertshaw defective gas valve? (Heating, Ventilation, and Air Conditioning (HVAC))
by lrg47 1/31/2010 10:10:08 AM(UTC)
Robertshaw gas valve (Heating, Ventilation, and Air Conditioning (HVAC))
by feded 10/12/2009 8:56:43 PM(UTC)
OLD Modern Maid Robert Shaw Oven (Oven Repair (including Ranges and Cooktops))
by Hodgi 9/23/2009 2:35:58 PM(UTC)
10 yr old robert shaw gas valve installing new one (General Talk)
by jess.good@live.com 12/9/2008 3:26:59 PM(UTC)
Robertshaw gas valve question (bad regulator?) (Heating, Ventilation, and Air Conditioning (HVAC))
by Fong 6/10/2008 7:25:20 AM(UTC)
Old Robert Shaw thermostat connections (Oven Repair (including Ranges and Cooktops))
by jkosanke 5/1/2008 8:19:16 AM(UTC)
robert (Oven Repair (including Ranges and Cooktops))
by rmitche2@stx.rr.com 2/4/2008 7:50:49 AM(UTC)
