feded
#1 Posted : Monday, October 12, 2009 8:56:43 PM(UTC)
feded
Hi, I am replacing a nat gas heating contol on a heat-n-glow fireplace - old one a Robertshaw 7000 MVRB-S-LC with a new 710 series millivolt control. The wiring diagram is exactly the same on both however the new one has a jumper wire from the safety magnet to the thermopile. The old unit does not have a safety magnet but has what appears a tube that runs to the pilot area - theres also the thermopile and the tube that carries the gas to the pilot light. - so three items there. Since this is on a fireplace I do not have a thermostat control but have a wall switch to turn on / off . So the wall switch takes the place of the thermostat, is this correct? Why does the old unit which is a millivolt unit not have this safety magnet but a thermocouple connection instead? I have read your previous posts but just wanted to know alittle more.
Thank You
feded
#2 Posted : Tuesday, October 13, 2009 12:00:20 PM(UTC)
feded
I cannot get the pilot to lite. The safety valve should be open at room temp correct? Heating the thermopile will cause it to close? At room temp I should be able to blow air through the valve?
need wiring diagram for magic chef furnace and ac unit with robertshaw gas valve and (Heating, Ventilation, and Air Conditioning (HVAC))
by bigdaddy88 8/2/2012 4:16:30 PM(UTC)
Robertshaw gas valve question (bad regulator?) (Heating, Ventilation, and Air Conditioning (HVAC))
by Fong 6/10/2008 7:25:20 AM(UTC)
