gdmonk
#1 Posted : Friday, August 21, 2009 12:08:21 PM(UTC)
gdmonk
dryer works but has skweel and scatching sound, like drive or idle pully has caught something. my problem is how the dryer comes apart? the back and bottom is solid and the top is not popping off, Any help?
#2 Posted: : Friday, August 21, 2009 3:34:00 PM(UTC)
Open the door and remove the screws holding the top panel through the door frame. Lift up the top panel and remove the four screws (2 - on the top and 2 on the bottom) holding the front panel. Remove the rear access panel and remove the belt from the idler and motor pulleys.
Here are the breakdown diagrams and Replacement parts for GE DX4500EA1WW | AppliancePartsPros.com
GE electric dryer (DCVH680EJ1MS) Stops 2 mins. Into Cycle (Dryer Repair)
by bjohns610 9/30/2019 2:15:08 AM(UTC)
GE electric dryer rotating switch (Dryer Repair)
by pamelaw72 8/21/2019 2:39:50 PM(UTC)
GE Electric Dryer Shuts Off Mid-Cycle (Dryer Repair)
by Dynocon 10/22/2015 5:20:00 PM(UTC)
GE Electric Dryer - Belt / slide fix, did I break something? (Dryer Repair)
by bmilcs 8/23/2015 1:23:57 PM(UTC)
GE electric Dryer running then had a smell and stopped (Dryer Repair)
by DDEAN 5/12/2015 7:52:33 PM(UTC)
GE Electric Dryer won't start (Dryer Repair)
by brosnan 12/13/2014 2:08:12 PM(UTC)
GE Electric Dryer (Dryer Repair)
by josiec 8/20/2013 12:38:26 PM(UTC)
GE electric dryer won't heat up (Dryer Repair)
by jrogers 7/4/2013 11:55:26 AM(UTC)
GE Electric Dryer suddenly got loud (Dryer Repair)
by Newbie2 12/15/2012 6:58:35 PM(UTC)
GE Electric Dryer - Won't Start (Dryer Repair)
by stockejj 10/31/2012 8:38:36 AM(UTC)
GE Electric dryer no start (Dryer Repair)
by TravisG 4/12/2011 1:30:52 PM(UTC)
GE electric dryer wont start (Dryer Repair)
by cojay 3/13/2011 6:38:17 PM(UTC)
trouble replacing belt GE Electric Dryer (Dryer Repair)
by lshelly40 2/6/2011 11:23:33 AM(UTC)
GE Electric dryer, no heat (Dryer Repair)
by khoshkkon 11/25/2010 10:38:07 AM(UTC)
Ge Electric Dryer Start Switch (Dryer Repair)
by lwpeters52@hotmail.com 10/16/2010 2:06:48 PM(UTC)
