Hi here is my question.
Two months ago my washing machine started with a very strong noisy while was in th espining cycle, then we saw water n the floor, and finally didn't complete the spinning cycle and the clothes still wet. I had to do it by hand to rainse the water).
My wife told me that sometimes when she would check the base inside, would work again in the spinning, but now it is not.
I took everything a part, including the belt on the motor(2 pulley). I don't see the belt damaged with debri. Someone tolde me that could be the pump. So, how do I know for sure is the pump that produced this original problem....noysy, water leak on the floor etc etc
thank you, jose
