Hello there, first thankyou for help. Kenmor gas oven bake it turn on properly after on a few minit later Tern off by itself , agan a few minit it turn on,this its haben for constantly, no error cod, its only in key border show pr heat. what could be the problem ? maybe ( majos spark & gas relay).please give me your feedback. Thank-you
Groups: APP Team
Hi, the problem you describing most likely can be solved by replacing the bake burner(comes as a kit with ignitor). The burner Part number: AP3598752
There is two burner there I will tray to Chang and see if it works with other one if not I will order one set soon. Agean thank-you for help !
tech student
(Washer Repair)
by azkidane
2/11/2012 6:15:21 AM(UTC)
Tech student
(Washer Repair)
by azkidane
1/28/2012 9:47:51 PM(UTC)
Tech student
(Washer Repair)
by azkidane
12/28/2011 8:47:04 AM(UTC)
