Hello there ,,,, whilpool front lode washer, water not fill enough in the unit,also the softner in the dispencer not geting water, the softner stayed until the sycle finished . what could be the problem?
The water inlet screens could be plugged or the water valve could be at fault and needs to be replaced.
