Our dryer won't start. I have replaced the thermistor (that didn't solve it) and i think i may need a control panel. the error codes that came up on the initial overide test showed co1 and o72. now only co1 after thermistor. is co1 the control panel? based on what i see when i search around that would be my next best step...just won't some advice before i order part. thanks
I don't see anything about them codes in the tech sheet for this model dryer. Check your door switch.
