I have had my Indesit cooker for approximately 4 years now and no problems till now, i will light the oven and about 5-10 minutes later the gas goes out, i have to keep repeating this every 10-20 minutes so am unable to cook properly, is this a serious problem and will it cost me to have it sorted out?:confused:
Yes, mine does the same thing. If I keep a burner on the stove on the oven says on. Very inconvenient and also costly. Would this be a problem with the igniter?
Quote:Would this be a problem with the igniter? I have no idea how Indesit cooking appliances are designed (not being sold here in North America) however I very much doubt any kind of ignitor failure would cause a problem with a totally separate burner. JMO Dan O.
