kenmore gas range . wont stay lit .How far should that sensor be sticking out of the burner assembly. Is that called a thermocouple and is that replaceable or does the whole safety valve have to be replaced . Im missing 2 numbers out of my model number ,scratched off
Originally Posted by: bearman65 kenmore gas range . wont stay lit .How far should that sensor be sticking out of the burner assembly. Is that called a thermocouple and is that replaceable or does the whole safety valve have to be replaced . Im missing 2 numbers out of my model number ,scratched off Bearman, The closest model number I could find was 9117218810 . This model does have a thermocouple and safety valve and pilot assembly. Part number: AP2013877
There is no part number for a thermo coupler, and it is most likely part of the safety valve. The Sears part number for the safety vave is 321755 , and is no longer available from the manufacturer. You may want to search the internet for a possible replacement or substitute part, or a parts re building company to get a valve thermo coupling assembly(the part number should help). Good Luck, :) :) :)
