I'm not sure of the age of this machine. I removed the inner basket because it rusted and broke loose almost 3/4 the way around the part of the inner tub that wraps around the shaft. I think the name of the part that I may need along with the inner tub is the tub support (basket spin tube). Directly underneath this is the rubber gasket that is attached to the outer tub. It isn't smooth and has a lot of rust built up on it. I wonder if I could get away with leaving it and putting the new inner tub on until whatever may happen. Could you please help me.. tks.:confused:
Originally Posted by: cglover54 I'm not sure of the age of this machine. I removed the inner basket because it rusted and broke loose almost 3/4 the way around the part of the inner tub that wraps around the shaft. I think the name of the part that I may need along with the inner tub is the tub support (basket spin tube). Directly underneath this is the rubber gasket that is attached to the outer tub. It isn't smooth and has a lot of rust built up on it. I wonder if I could get away with leaving it and putting the new inner tub on until whatever may happen. Could you please help me.. tks.:confused: Cindy, As long as the two square tabs on the top of the spin tube, under the drive block Part number: AP3114270
Tks a Lot! I ordered the wrench from you and received it yesterday....tks again..
Originally Posted by: cglover54 Tks a Lot! I ordered the wrench from you and received it yesterday....tks again.. Cindy, Great, it'll make things a lot easier to work with. Just be careful, and you'll do fine. Let us know how it turns out. :) :) :)
