I have a Whirlpool top load washer and it will not spin on it's on if you turn it by hand to get it started it will go I think the clutch is slipping but not sure any reply will be aptreciated everthing else works fine.
Hi Tinstar
I suggest you look at the post "Whirlpool Spin Problem" which should be on the first or second page and see if that does not help you.
Let us know if you have more questions or need additional info.
Good luck
