DRWALLIE
#1 Posted : Sunday, March 15, 2009 6:20:28 PM(UTC)
DRWALLIE
Not using range the other day and the thing started beeping.Have error code F7 and flashing E6.Pressed clear and a few minutes later same thing.Turned off power for 20 minutes.When turned back on same thing.Exact model is not listed at appliance pro but a model near this one is listed and under fault code F7 is not listed?
kayakcrzy
#2 Posted : Monday, March 16, 2009 4:10:01 AM(UTC)
kayakcrzy
From the digging that I have done, it points to the ERC control Board. The part # is WB27T10416. Tom
GE electric range - nothing works but the clock (Oven Repair (including Ranges and Cooktops))
by Jelltronic 5/15/2022 6:28:03 AM(UTC)
GE Electric Range Keeps turning off (Oven Repair (including Ranges and Cooktops))
by Guest 5/7/2021 9:58:17 AM(UTC)
GE Electric Range - nothing heats (oven or burners) (Oven Repair (including Ranges and Cooktops))
by tgtn7723 11/29/2020 5:29:31 AM(UTC)
GE Electric Range not maintaining temperature. (Oven Repair (including Ranges and Cooktops))
by Flicker87 11/24/2015 7:53:57 PM(UTC)
Really old GE electric range... HELP (Oven Repair (including Ranges and Cooktops))
by pinkimarie 12/3/2013 2:27:48 PM(UTC)
GE Electric Range, Oven (Oven Repair (including Ranges and Cooktops))
by Hanne555 4/28/2013 5:24:50 AM(UTC)
GE Electric Range - Display/oven clicks, cuts on and off. (Oven Repair (including Ranges and Cooktops))
by GeorgePo 12/27/2012 3:17:30 PM(UTC)
GE electric range top shorted out (Oven Repair (including Ranges and Cooktops))
by brizander 9/12/2012 2:22:52 PM(UTC)
1960's GE Electric Range 4-connector elements (Oven Repair (including Ranges and Cooktops))
by billca 8/13/2012 12:55:44 PM(UTC)
GE electric range (Oven Repair (including Ranges and Cooktops))
by CHIEF1096 9/2/2011 11:24:56 AM(UTC)
ge electric range (Oven Repair (including Ranges and Cooktops))
by linda kolonsky 7/28/2011 4:46:24 PM(UTC)
GE Electric Range Part (Oven Repair (including Ranges and Cooktops))
by MDHome 1/29/2011 7:28:10 AM(UTC)
GE Electric Range won't get hot unless you turn it way up (Oven Repair (including Ranges and Cooktops))
by axrowland 1/10/2010 7:46:45 PM(UTC)
Replacing insulation in GE electric range/oven (Oven Repair (including Ranges and Cooktops))
by JudgeHooke 1/4/2010 1:23:24 PM(UTC)
GE electric range thermostat replacement (Oven Repair (including Ranges and Cooktops))
by Arnie 3/18/2009 8:38:23 AM(UTC)
