woodrose
#1 Posted : Saturday, January 29, 2011 4:45:23 PM(UTC)
woodrose
I just replaced a harness on a JGP 328 GE cooktop which fixed a continuous sparking problem, Additionally I replaced a igniter on a burner that hadn't sparked for years which hasn't solved the problem.
When I clase the gap to the burner plate with a screw driver I get a weak spark.If I pull the igniter up and hold it with pliers it throws a long spark to the plate. Also if you get the wire end near the plate it throws a long spark out of that end.I assumed the white part was a insulator but I got a jolt just touching it. Both the old and new igniters act the same. Need help.
GE Cooktop Igniter problems (Oven Repair (including Ranges and Cooktops))
by KatyTx 12/27/2008 7:27:46 PM(UTC)
GE cooktop Igniter (Oven Repair (including Ranges and Cooktops))
by SteveA 8/20/2008 3:09:06 PM(UTC)
