tedward77
#1 Posted : Sunday, November 16, 2008 6:47:50 AM(UTC)
tedward77
It takes our dryer 2-3 80 min cycles to dry clothes where it used to take 1. I have read suggestions you've made to other customers and this is what I've done. I have noticed during the load, that the heating coils will glow for a while, turn off, and then glow again. I took the dryer apart and cleaned out all the duct work within the dryer. I then eliminated the duct work through the house by running the dryer disconnected. The output temp of dryer without clothes is between 130 - 140 F. Once a load of wet clothes is in, the temp will remain between 95 - 100. Even with the dryer disconnected, it still takes 2-3 cylces to dry. Also, I don't know if this is relevant, but the automatic sensor dry has not been working so we just use time dry. Any suggestions?
Thank You,
Ted
#2 Posted : Sunday, November 16, 2008 6:49:14 PM(UTC)
Hi Ted,
I would recommend to replace the cycling thermostat (#230 on the break down diagram) first and check the blower wheel.
If it would not help then replace the temperature switch (#87 on the break down diagram).
Here are the break down diagrams for the GE dryer Model DCXR453EV0AA
tedward77
#3 Posted : Monday, November 17, 2008 3:51:20 PM(UTC)
tedward77
Thanks Gene, I'll replace those parts.
Ted
#4 Posted : Monday, November 17, 2008 4:53:02 PM(UTC)
Keep us posted.
Maytag Gas Dryer Timer not Advancing = Clothes not Drying (Dryer Repair)
by troxel 3/4/2014 6:43:42 AM(UTC)
clothes not drying (Dryer Repair)
by wu5062@cox.net 8/31/2013 8:27:35 AM(UTC)
Clothes not drying (Dryer Repair)
by dlw918 7/3/2012 9:24:41 AM(UTC)
Dry has heat but clothes not drying (Dryer Repair)
by spayonk 1/17/2012 8:29:42 AM(UTC)
dryer heats intermittently,clothes not drying properly (Dryer Repair)
by keithblake@peoplepc.com 3/12/2011 10:23:53 AM(UTC)
by TJFox15 1/22/2011 12:34:30 PM(UTC)
Clothes not drying compleatly (Dryer Repair)
by Marc Anderson 11/29/2010 4:32:45 PM(UTC)
Clothes not drying complete.....GE dryer (Dryer Repair)
by FDAR 8/14/2009 3:25:07 PM(UTC)
Top of Dryer hot but clothes not drying (Dryer Repair)
by sween 10/27/2007 10:32:22 AM(UTC)
