I'm experiencing hollow ice. I've replaced the ice maker unit, and need to change out the water valve(s). I find on my 'fridge that there are two valves, with two solenoids each. The one which attaches to the water supply has two green solenoids; the other valve has one red and one green solenoid.
Are these valves the same? Should I replace them both? Any help appreciated. Thanks,
Knox G.
