My GE washer will not agitate or spin. It doesn't appear to be the lid switch or the fuseable link in the white/red wire. The motor has a green LED that flashes about once per second, which seems to be normal. I hear no other noise when it should go into those cycles. It fills and drains, then fills and drains.
I'm not sure if it's a switch, the timer, the motor or what.
Hi! I just noticed a bunch of people have read your washer repair post, but no one is replying, and I thought maybe its because its in the dryer repair section...;)
