2 Pages12>
WG
wrajgreen
#1 Posted : Sunday, December 16, 2007 5:38:35 PM(UTC)
wrajgreen
My dishwasher will fill and drain but no pump circulation. If its the pump/motor, is it easy to replace and need part #. Thank you.
kawfeeman
#2 Posted : Sunday, December 16, 2007 5:41:12 PM(UTC)
kawfeeman
firstly, you should try to determine exactly what happens.. the unit fills with water and water remains in the tank ?? Does the circ pump ever turn on ??? sometimes the circ pump motor could be bad but it could also be the impeller only ?
wrajgreen
#3 Posted : Monday, December 17, 2007 5:16:17 AM(UTC)
wrajgreen
I can hear and feel a slight buzzing sound coming from the capacitor and motor. Orig there was water at the bottom of the tub at the end of its full cycle without any cleaning. Powercycling the d/w did not help get any activity started except the count down display. When I cancelled the cycle using the buttons, the water would drain and refill. I cannot tell from inside the tub if anything is jammed. I did take out the bottom filter but only have access to a small hole in the pump asm.
wrajgreen
#4 Posted : Monday, December 17, 2007 5:19:20 AM(UTC)
wrajgreen
kawfeeman
#5 Posted : Monday, December 17, 2007 5:21:41 AM(UTC)
kawfeeman
there are two pumps in your dishwaher .. a drain pump and a circ pump.. you'll have to be comfortable removing the d/w from beneath the cabinet ... not for everyone... beneath you stainless wash tank is a white basin housing all of the components... ...you'll need to look in there, with the power off ( w/ a flashlight and good eyes .. )
wrajgreen
#6 Posted : Monday, December 17, 2007 5:42:24 AM(UTC)
wrajgreen
The d/w is out with the water line and power disconnected. If I tilt the bottom up I see the white basin. I guess I need to lower the basin to gain access to the components. What would the circulation pump look like in comparison to the drain.
kawfeeman
#7 Posted : Monday, December 17, 2007 6:21:01 AM(UTC)
kawfeeman
circ pump can be view from the front but it comes out from the right side and the drain pump can be viewed and removed from the front... lots o' screws ( including torx t-20 screws ) not an easy job ...
DaleHurd
#8 Posted : Monday, December 17, 2007 6:09:15 PM(UTC)
DaleHurd
I have replaced a circ pump on SHU4306. 1st Remove from under the counter and disconnect power, water and drain. Then you have to disassemble the base from the main "cabinet" cabinet of the dishwasher. There are a bunch of screws and wiring assemblies, but it isn't hat bad. Just FYI...if yopu hear a humming...you may want to check for a blocked impeller or a bad capacitor first.
wrajgreen
#9 Posted : Tuesday, December 18, 2007 2:44:53 AM(UTC)
wrajgreen
Can you please how to do that. From inside the tub, I cannot see where to check. I have removed the screen and inserts .The only thing I can find is a small hole where the water drains into. There are two screws holding the asm in place with another screw at the bottom. Don't know what the screw is for. Also to gain access to the components. Do I drop the basin while the d/w is on its back. When you say, right side, does that mean after removing the basin, the machine is back on its legs and work from the bottom?????? Thank you for the info.
DaleHurd
#10 Posted : Tuesday, December 18, 2007 8:26:42 AM(UTC)
DaleHurd
If you reach down in the small hole (with your finger) you should feel the impeller blades. You should be able to spin them freely. If not, there is probably something jammed in there. Try to force it a little (Don't break it)...you may be able to free it up.
Not sure how to tell if the capacitor is good. I would check for any signs of leaking.
To remove the circ pump you are taking the whole machine apart. So I really don't think left/right is an issue. The machine is literally split in two at this point. If you are patient it really isn't that bad...and now there is not another repair that will intimidate you as far as this machine is concerned.
Best of luck!
Whirlpool gas dryer model WGD8300SW2 (Dryer Repair)
by Guest 4/20/2024 7:14:50 AM(UTC)
Whirlpool WGD86HEBW1 Dryer (Dryer Repair)
by CaesarC 3/30/2023 8:46:09 AM(UTC)
Whirlpool Duet dryer WGD9400 knob Removal (Washer Repair)
by Guest 1/1/2023 8:41:47 AM(UTC)
GE GSS25WGTGBB - Control panel dies when turning on dispenser light (Refrigerator & Freezer Repair)
by noparts 9/19/2022 6:17:40 AM(UTC)
Whirlpool Dryer WGD5300SQ0 taking too long to dry (Dryer Repair)
by aryan 4/10/2022 3:24:26 PM(UTC)
Maytag CWG3600AAB Gas Wall Oven (Oven Repair (including Ranges and Cooktops))
by bdgabriel1 2/28/2022 7:07:47 AM(UTC)
wgd5300sq0 new dryer motor and blower wheel. But blower wheel keeps falling off (Dryer Repair)
by Ebnuno 2/6/2022 7:55:20 AM(UTC)
Whirlpool dryer heats for a bit then stops (WGD6400SW1) (Dryer Repair)
by don_caruana 9/2/2020 6:35:54 PM(UTC)
Whirlpool WGG745S0FS Double oven gas range (Oven Repair (including Ranges and Cooktops))
by BygDon 11/26/2019 12:49:13 PM(UTC)
Whirlpool Cabrio Dryer Model wgd6200sw2 is making a lot of noise (Dryer Repair)
by creamerdp 4/25/2017 12:23:56 PM(UTC)
hawg28 (Refrigerator & Freezer Repair)
by hawg28 9/15/2014 5:04:42 AM(UTC)
Whirlpool Cabrio Platinum Dryer WGD8200YW2 (Dryer Repair)
by Mcmk1996 7/30/2014 5:35:04 AM(UTC)
Frigidaire FFU14F5HWG upright freezer not freezing (Refrigerator & Freezer Repair)
by Curlymmx 5/5/2012 6:41:49 PM(UTC)
Whirlpool WGD5830SW0 Flame comes on then shuts off (Dryer Repair)
by Kbolton 4/14/2012 11:20:23 AM(UTC)
maytag cwg402 will not ignite. (Oven Repair (including Ranges and Cooktops))
by junelou 1/14/2012 8:35:19 AM(UTC)
2 Pages12>
