I replaced the Washer Temperature Switch (part #661614) - How To Replace And the Washer Water Level Switch (part #W10337780) - How To Replace which I thought would fix my problem. But now I have to turn the water feed off otherwise the water doesn't shut off. What part might I need to check next? Thanks
Groups: Expert
Need the model number of the washer.
Eric
Originally Posted by: fairbank56 Need the model number of the washer.
Eric Model number is 110 226 32100
