Hi guys, hope I get some help here.. My kenmore washer(Elite OASIS, HE, model no: 110.27062603) started behaving abnormally. It starts by itself and runs thru C#(1-10) and stops by itself and then restarts after some time.. In the trouble shooting guide which I got with washer does not have error code "C". I have no idea what needs to be done as mostly I see error code "F" on google search. Could you guys pls give me an insight on what could be wrong? Thanks in advance..
Wow, it is not supposed to start by itself.
Difficult to diagnose without being in front of the machine. I am going to say that the probable cause is something stuck on the user interface, but the only way to be certain is to purchase the part and try it.
It can also be the main control board.
Sorry I cannot be more definitive, but since you are not getting a good error code message that tells us anyting it is hard to say anything definitely. That's the problem with microprocessor controls these days.
I think the user interface board is a good bet. Good luck
Ok, sounds like your diagnostics also suggests the user interface as the problem, as we suspected.
The Sears part and the APP part number are the same part, you are just looking at an APP number rather than the Sears Parts number. Forget about the number from the other post you found, you will want the number that corresponds to your model.
I would call in the part order to APP to make certain you get the right one, and check with them about the return policy in case for some reason it is not correct. (We are just volunteers and are not associated with APP)
Good luck.
