Wilkinsonbill
#1 Posted : Tuesday, May 5, 2009 11:50:50 AM(UTC)
Wilkinsonbill
Can anyone tell me how to remove and replace the icemaker unit on a sears kenmore elite side by side with on the door ice dispenser. I could remove the icemaker door but the icemaker itself is another story. Thanks Bill
woodchuckie
#2 Posted : Tuesday, May 5, 2009 12:58:57 PM(UTC)
woodchuckie
Yours looks like the kind that hangs on the side wall with a bracket. You loosen two top and one bottom screw and lift the ice maker off the bracket and then unplug the wiring harness.
Wilkinsonbill
#3 Posted : Wednesday, May 6, 2009 3:39:40 AM(UTC)
Wilkinsonbill
Thanks Woodchuckie...was able to find the 3 screws and replace the unit. Unfortunately still doesnt make ice so guess i need to troubleshoot further. Tray fills with water but seems that it may be sensing that the door icebucket is full....when its empty. Thanks again
woodchuckie
#4 Posted : Wednesday, May 6, 2009 4:36:23 AM(UTC)
woodchuckie
Does the water freeze? Is this a new ice maker?
Wilkinsonbill
#5 Posted : Wednesday, May 6, 2009 7:18:40 AM(UTC)
Wilkinsonbill
I think its actually made and dispensed 2 trays in about a 12 hour period. I put my hand in the icemaker and the water was frozen...next time i checked it was just cold water. Its either intermittent or terribly slow...yes it was a new OEM icemaker.
woodchuckie
#6 Posted : Wednesday, May 6, 2009 8:16:56 AM(UTC)
woodchuckie
Check the freezer temp. It should be around 5 to 10 degrees.
Wilkinsonbill
#7 Posted : Wednesday, May 6, 2009 3:14:26 PM(UTC)
Wilkinsonbill
Freezer temp is at 0 degrees and it checks out. I have heard the ice dispensing now but its exceedingly slow
Wilkinsonbill
#8 Posted : Saturday, May 9, 2009 1:53:59 AM(UTC)
Wilkinsonbill
Therre is a tray of frozen ice but it hasnt dispensed a tray in 2 days. Therre is also a ice tray sensor on the inside door and a on off switch with a flashing red light on the other side that flashes in pairs when the freezer door is open. Could one or both of these be the problem...both seem easy to replace. thanks Bill
