sultan62
#1 Posted : Tuesday, April 9, 2013 10:08:39 AM(UTC)
sultan62
I recently moved a Kenmore Dishwasher model no. 363.14589100 that worked fine, and after moving I cannot get the dishwasher to fill. I have checked the pressure right before the water inlet valve, and it is adequate. I have checked the screen filter at the water inlet valve, and have tested the valve for continuity as well as the wiring coming in to the valve for voltage. All of this appears to function correctly:
Voltage: ~120V
Resistance: ~1100Ω
If anyone has any tips, it would be appreciated. I'm getting tired of washing dishes by hand. :(
#2 Posted : Tuesday, April 9, 2013 12:14:01 PM(UTC)
Since the fill valve has 120 volts across it when it should be filling. I am assuming this is what you mean by "Voltage: ~120V" and does not open.
I would replace the valve.
sultan62
#3 Posted : Tuesday, April 9, 2013 12:20:51 PM(UTC)
sultan62
Even though the valve shows continuity?
#4 Posted : Tuesday, April 9, 2013 1:47:39 PM(UTC)
Yes.
Just because the solenoid coil has continuity does not mean that the plunger pulls down opening the orifice re: it could be a mechanical problem in the valve.
sultan62
#5 Posted : Tuesday, April 9, 2013 1:59:31 PM(UTC)
sultan62
Thanks-I'll check it and post back.
sultan62
#6 Posted : Monday, February 10, 2014 12:38:29 PM(UTC)
sultan62
I just came back with another appliance question and realized I didn't respond to this thread. For that I apologize.
I don't have anything helpful to add to this thread, as I came across a functioning dishwasher that I could have for free provided I hauled it away, so I never did order an inlet valve or otherwise solve the issue with the old dishwasher. Thanks again for the help provided.
Dishwasher Will Not Fill With Water (Dishwasher Repair)
by sfora71 10/7/2016 8:29:08 AM(UTC)
Kenmore 665.13893 Dishwasher Will Not Fill - New Water Inlet (Dishwasher Repair)
by ferant316 1/28/2013 3:18:58 PM(UTC)
Dishwasher will not fill with water (Dishwasher Repair)
by field.chuck@yahoo.com 6/10/2012 2:30:05 PM(UTC)
My dishwasher will not fill w? water (Dishwasher Repair)
by fhomefixer 4/16/2012 10:34:04 AM(UTC)
Dishwasher will not fill (Dishwasher Repair)
by Jbrobbins83 9/23/2011 5:18:38 PM(UTC)
Kitchen Aid Dishwasher will not fill (Dishwasher Repair)
by mdcook 5/16/2011 12:32:46 PM(UTC)
dishwasher will not fill w/water (Dishwasher Repair)
by rde750 1/14/2011 10:47:06 AM(UTC)
GE dishwasher will not fill with water! (Dishwasher Repair)
by joyelizabeth 12/3/2010 2:36:57 PM(UTC)
Maytag Dishwasher Will Not Fill With Water (Dishwasher Repair)
by jwpurdy 10/25/2010 7:21:33 PM(UTC)
GE Dishwasher Will Not Fill (Dishwasher Repair)
by kodiak_dude 9/8/2010 2:05:24 PM(UTC)
dishwasher will not fill (Dishwasher Repair)
by wledswift 12/15/2009 12:51:34 PM(UTC)
by nancyrice 7/3/2009 6:22:44 PM(UTC)
bosch dishwasher will not fill water (Dishwasher Repair)
by loas 6/28/2009 1:39:25 AM(UTC)
Bosch Dishwasher will not fill (Dishwasher Repair)
by gundogofct 2/9/2009 11:11:42 AM(UTC)
Bosch Dishwasher Will Not fill with water (Dishwasher Repair)
by drskinner 4/26/2008 9:24:44 PM(UTC)
