outlawspeedqueen
#1 Posted : Tuesday, January 10, 2012 5:53:55 PM(UTC)
outlawspeedqueen
It gets stuck during the cycle. I have changed the drain valve. checked the water level tube. I am not sure what to try next. It seems to get stuck on 17 min and I advance it then it gets stuck on 12 min and stays forever. When I advace it thru the water never drains out.
sidfink43
#2 Posted : Thursday, January 12, 2012 4:47:40 PM(UTC)
sidfink43
If you will post a model number someone may be able to help.
In the meantime, look under the top cover or inside the lower service panel to see if you can find some tech notes and use them to do some diagnostic testing.
outlawspeedqueen
#3 Posted : Thursday, January 12, 2012 5:04:22 PM(UTC)
outlawspeedqueen
it was a bra wire in the drain that had the drain clogged up. There was large amounts of lint and 30 dollars in coins..........
sidfink43
#4 Posted : Friday, January 13, 2012 4:40:54 AM(UTC)
sidfink43
That happens lot, glad you got it fixed and thanks for updaing us, that is very helpful for the people that read this Forum.
Bosch Nexxt 500 or Speed Queen front loader? My HE3t is dead after 4 years (Washer Repair)
by CircoTribe 11/6/2008 7:31:26 PM(UTC)
