I'd like to get into the cabinet without destroying it. Does the top lid pop open with a pry tool ? And once i get the top open can i get the front panel off ?
The front panel is fastened at the top by 2 metal spring clips, and at the bottom by 2 metal tabs which protrude from the base of the unit into slots in the panel bottom. Locate 2 spring clips between the top cover and front panel by aligning a putty knife with left or right edge of lid. Insert the putty knife and push forward to release clips. Rotate the front panel forward and lift off the bottom tabs. Here are the breakdown diagrams and Replacement parts for General Electric WPSR3100W1WW Washer | AppliancePartsPros.comGene.
Originally Posted by: Gene The front panel is fastened at the top by 2 metal spring clips, and at the bottom by 2 metal tabs which protrude from the base of the unit into slots in the panel bottom. Locate 2 spring clips between the top cover and front panel by aligning a putty knife with left or right edge of lid. Insert the putty knife and push forward to release clips. Rotate the front panel forward and lift off the bottom tabs. Here are the breakdown diagrams and Replacement parts for General Electric WPSR3100W1WW Washer | AppliancePartsPros.comGene. Thanks Gene, you were very helpful. Once I removed the front panel all I had to do was tighten the drive belt.
You are welcome. I'm glad it's up and running.
