2 Pages<12
dnchrist
#11 Posted : Tuesday, September 16, 2008 12:03:32 PM(UTC)
dnchrist
Will do! I've got to go pick up my son from school, so it will be a couple of hours.
Thanks!
Dave
libertyappl
#12 Posted : Tuesday, September 16, 2008 12:03:52 PM(UTC)
libertyappl
Look in the back by the compressor if it's anything like the one I'm currently viewing.
nat
dnchrist
#13 Posted : Tuesday, September 16, 2008 2:10:38 PM(UTC)
dnchrist
I found the timer! It is on the back near the compressor, but in a spot I wouldn't have found it if you hadn't told me where to look. I read the wiring diagram and read the voltage across the timer and it is fine. I then set up the meter so that I could see when the timer turned on. I then turned the timer until it manually fired. It is melting the ice, so that tells me the heating coils are working. So it is beginning to look like that timer.....
libertyappl
#14 Posted : Tuesday, September 16, 2008 2:13:37 PM(UTC)
libertyappl
I would have to say the timer. Is there a part numbr on it?
Nat
dnchrist
#15 Posted : Tuesday, September 16, 2008 2:18:38 PM(UTC)
dnchrist
Out of curiosity, how long should the heating coil be on? I understand it is supposed to cycle about 4 times a day...
libertyappl
#16 Posted : Tuesday, September 16, 2008 2:24:41 PM(UTC)
libertyappl
That's ok, I'll be on & off.....just put an apple pie in the oven ;o)
Nat
dnchrist
#17 Posted : Tuesday, September 16, 2008 5:14:54 PM(UTC)
dnchrist
Thanks for all the help! Seems to be working like a champ now, but I'll show her where the timer is, and what to do if it freezes up again.
You have been a huge help!
Best to ya!
Dave
libertyappl
#18 Posted : Tuesday, September 16, 2008 5:45:28 PM(UTC)
libertyappl
The defrost cycle doesn't last very long about 30 minutes usually. If advancing the timer helped then that's the part you are going to want to replace.
Nat
dnchrist
#19 Posted : Wednesday, September 17, 2008 6:31:56 AM(UTC)
dnchrist
Thanks, Nat!
libertyappl
#20 Posted : Wednesday, September 17, 2008 6:45:14 AM(UTC)
libertyappl
You're welcome. If you need anything else let us know.
Nat
2 Pages<12
