already replaced defrost termination switch freezer gets to warm before it gets cold again and frig gets to warm as well
Here are some parts breakdowns. I could not find an exact match to your model number.
Since the freezer is getting to warm I would say that the thermostat is the most likely culprit.(Item 3 Section 2). Sometimes they can get sluggish.
I am assuming that everything else runs and sounds OK.
You may want to check the time it takes for a defrost cycle. Should be 20 to 30 minutes. It usually says on the timer. |
THIS FORUM IS DEAD!!!!!!! |
