I have a Whirlpool slide in range that the oven won't work. The stove top burners work fine. When I touch the keypad for the oven controls, it won't turn on. Thanks
Here are your parts Replacement parts for WHIRLPOOL GY399LXUS02 30" SLIDE-IN ELECTRIC RANGE | AppliancePartsPros.comHere is a manual covering this unit. http://appliancedigest.c...ric-range-service-manualYou have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer. [COLOR="DarkRed"] When I touch the keypad for the oven controls, it won't turn on.[/COLOR] I am not sure what will not turn on so need more info. There is an ambient sensor in the power to the control board. Also the wiring diagram shows a DLB relay in the line to the element. I could not find this in the parts and it does look like it is not on the control board but then I could not find a wiring diagram for this specific unit so cannot be sure if the unit has one. |
THIS FORUM IS DEAD!!!!!!! |
The oven controls do not work. There are bake, broil, connvect bake, convect roast, favorite cooking options tabs, that when you press them, nothing happens. There is also a warm button that does work.
The oven controls do not work. There are Bake, Broil, Convect bake, Convect Roast, and favorite cooking options, that when you press on them nothing happens, the oven will not work There is a warm button that will warm the oven to 140 degrees.
Sounds like it is a keyboard or a control board problem.
Be suire to unplug the unit when working on it.
Connector Cleaning / Checking Unplug the unit Open it up Remove the ribbon cable from the keypad to the control board at the control board. Clean the edge connector. If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive. Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here. Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates. Reconnect everything and give it a try.
If the above does nothing then it is sort of a crap shoot as to what to replace as they do not give a pinout diagram of the keyboard so you cannot really check it. I would put the keypad at the top of the list but that is just a guess. |
