jonanles
#1 Posted : Thursday, July 31, 2008 4:31:53 AM(UTC)
jonanles
I am having an issue with my washer,it seems that it will not spin. the washer agitates and it drains but it will not spin. all I hear is a humming sound from the motor I assume, I took off the bottom plate to inspect the belt, it seems to turn ok and doesn't appear to be worn or frayed. I am not sure what to look at next, can I get some suggestions?
Thanks.
jonanles
#2 Posted : Thursday, July 31, 2008 7:38:40 AM(UTC)
jonanles
Yes it agitates, fills with water and drains,but it does not spin.
SkunkApe
#3 Posted : Friday, August 1, 2008 6:02:43 AM(UTC)
SkunkApe
Having similar problem.. Have you tried running the washer on delicate? Mine will spin on delicate but not any other mode. I've posted on this site and others. Will let you know what I find out. Also, is your motor turning even when the washer will not spin?
jonanles
#4 Posted : Friday, August 1, 2008 6:05:41 AM(UTC)
jonanles
I will have to try that. All I hear is a loud humming sound, I don't believe the motor is turning.
Whirpool washer will not spin (Washer Repair)
by Guest 1/27/2022 11:02:31 AM(UTC)
Washer Will Not Spin Out Water. (Washer Repair)
by Guest 6/5/2021 1:32:58 PM(UTC)
GE Profile Harmony washer will not spin - grinding (WPGT9150HWW) (Washer Repair)
by jmac2287 12/3/2019 11:25:46 AM(UTC)
Washer will not spin (Washer Repair)
by lftfield09 6/9/2017 4:58:09 PM(UTC)
Stacked Washer dryer- washer will not spin and empty (Washer Repair)
by anderson3818 6/8/2017 7:57:48 AM(UTC)
washer will not spin out.. (Washer Repair)
by coastie1160870 1/11/2017 10:41:54 PM(UTC)
GE washer will not spin (Washer Repair)
by MS104 5/10/2016 4:34:48 PM(UTC)
Maytag Atlantis Washer will not spin (Washer Repair)
by lvavis 8/26/2015 7:56:10 PM(UTC)
by howard6168 7/5/2015 5:47:41 AM(UTC)
Kenmore 800 Washer will not spin (Washer Repair)
by AnneKenzie 6/18/2015 12:01:29 PM(UTC)
Frigidaire Washer will not spin (Washer Repair)
by luvmylars 4/30/2015 11:33:25 AM(UTC)
washer will not spin out (Washer Repair)
by kdwarren16yrs 12/27/2014 6:42:50 AM(UTC)
ge profile washer will not spin (Washer Repair)
by ron dog 11/29/2014 5:27:31 PM(UTC)
Washer will not spin/drain (work) (Washer Repair)
by dupdc 8/20/2014 2:50:08 AM(UTC)
Whirlpool Cabrio Washer Will Not Spin (Washer Repair)
by pacdave 5/7/2014 6:40:52 PM(UTC)
