lisaslusher
#1 Posted : Sunday, April 6, 2008 12:46:48 PM(UTC)
lisaslusher
My oven started beeping and turning off. Finally I saw a code e2f6 and took the panel apart to check all the connections. It worked sporadically. I replaced the panel and it worked fine for about 2 weeks. Then the same thing started happening. Contol panels bite! I want to check the ground before I order the control board, but am unsure how to do that. Does this type of oven have a plug like a dryer? Any help would be appreciated. Thank you.
Lisa Slusher
#2 Posted : Monday, April 7, 2008 1:08:58 PM(UTC)
Hi Lisa,
Your oven does not have a plug and it should be hardwired. The junction box usually is behind the oven. You can find the complete wiring instructions in the installation manual.
Whirlpool recommendations concerning the "E2 - F6" error code are very uncertain. The cause of this problem could be control panel as well as control board without more specific diagnosis.
- The part number for the control board is AP3767567
Here are the break down diagrams for the Whirlpool oven Model RBD275PDQ12
Whirlpool Accubake Oven Not Working (Oven Repair (including Ranges and Cooktops))
by buddha61 11/15/2017 5:18:32 PM(UTC)
outer door installation on whirlpool accubake oven (Oven Repair (including Ranges and Cooktops))
by rldaustin 6/16/2014 4:15:59 AM(UTC)
Whirlpool Accubake Oven Clock display issue (Oven Repair (including Ranges and Cooktops))
by jimkenzie 2/24/2014 7:48:06 PM(UTC)
Whirlpool accubake oven isnt working (Oven Repair (including Ranges and Cooktops))
by chrisdod84 1/18/2013 12:16:23 PM(UTC)
Whirlpool Accubake Oven Problem (Oven Repair (including Ranges and Cooktops))
by 951prerun 6/6/2012 6:35:57 PM(UTC)
Whirlpool accubake oven door locking problem (Oven Repair (including Ranges and Cooktops))
by ZDM 10/16/2011 8:53:11 AM(UTC)
Whirlpool Accubake Oven Is Not Working (Oven Repair (including Ranges and Cooktops))
by peteshellz 7/20/2010 3:57:53 AM(UTC)
