weberce13
#1 Posted : Tuesday, January 12, 2010 8:31:07 AM(UTC)
weberce13
Recently our oven has stopped igniting. When I turn the oven on I can smell the gas and see the spark of the ignitor, however it does not light. Also our range top still ignites with no problem. Any suggestions to fix before I call a repairman? Thanks.
joexyz
#2 Posted : Tuesday, January 12, 2010 9:36:55 AM(UTC)
joexyz
The same thing happened to my oven the oven burner was clogged. Remove the bottom panel then like my oven there is another half panel to remove that exposes the burner and the igniter I took a small peice of wire and stuck it into the small burner holes that are closest to the igniter. Ofter doing this try turning on stove and see if the burner ignites. It worked for me.
Top Oven Will Not Ignite (Oven Repair (including Ranges and Cooktops))
by tdolecek 8/22/2013 11:46:26 AM(UTC)
by montville524 9/10/2012 7:01:58 AM(UTC)
Bosch oven will not ignite (Oven Repair (including Ranges and Cooktops))
by Stan Twardowski 4/16/2012 5:57:48 AM(UTC)
OVEN WILL NOT IGNITE (but igniter glows) (Oven Repair (including Ranges and Cooktops))
by dennis728 2/7/2011 5:44:03 PM(UTC)
Oven will not ignite (Oven Repair (including Ranges and Cooktops))
by Tracy H 12/19/2010 4:30:33 PM(UTC)
top burners & oven will not ignite (Oven Repair (including Ranges and Cooktops))
by cortlandt32 10/22/2010 5:16:37 AM(UTC)
Oven will not ignite, but broiler does (Oven Repair (including Ranges and Cooktops))
by BillWat 3/28/2010 4:12:20 PM(UTC)
Whirlpool gas range oven will not ignite (Oven Repair (including Ranges and Cooktops))
by kamzuk 1/2/2010 2:59:23 PM(UTC)
storm now oven will not ignite (Oven Repair (including Ranges and Cooktops))
by bonnie32f 8/17/2009 6:48:24 AM(UTC)
by jake59 6/24/2009 9:23:46 AM(UTC)
Gas Range Oven will not ignite (Oven Repair (including Ranges and Cooktops))
by Clubogilvie@yahoo.com 3/26/2009 12:03:07 PM(UTC)
Whirlpool gas oven will not ignite (Oven Repair (including Ranges and Cooktops))
by adamerik 11/5/2008 2:34:26 PM(UTC)
by gordo634 7/22/2008 5:45:05 AM(UTC)
Tappan 12-1863-10/03 Oven will not ignite (Oven Repair (including Ranges and Cooktops))
by areamon 6/4/2008 12:36:22 PM(UTC)
Burners and oven will not ignite (Oven Repair (including Ranges and Cooktops))
by bren 7/26/2007 12:32:27 PM(UTC)
