We are having no luck adjusting the oven temp. The "more" on the control panel is not working. It is set at 350 degrees and will not go higher. When setting the clock, could only go backwards to get the correct time. The broiler gives us a "5 E E (minus the top part of the 2nd E) and works on low when using the "less/minus".
Originally Posted by: bckaufmann We are having no luck adjusting the oven temp. The "more" on the control panel is not working. It is set at 350 degrees and will not go higher. When setting the clock, could only go backwards to get the correct time. The broiler gives us a "5 E E (minus the top part of the 2nd E) and works on low when using the "less/minus". Sounds like you need to replace the clock control board. It is where the comands originate, and your oven has a problem, with your comands. Tom ApplianceEducator.com - Parts
bckaufmannI am having the same problem. Have you had any luck?
Originally Posted by: cprader bckaufmannI am having the same problem. Have you had any luck? Check the circuit/clock board in the back. All we ended up doing was to check that all contacts were together. They must have jiggled loose when we moved it to our house..turned out to be simple fix for us after all :-)
