I had Code F-11 displayed, I unplugged unit then plugged it again and code was gone. oven worked with no problems. A week later display shows ERR-PF door locked,again I unplugged unit, when I plugged it in again, I held the clear button which cleared the display. This morning went to turn the oven on and got code F-90. I have checked the [F-11] code which is oven probe, at room temp it has 1080 ohms which is correct according to paper work that came with stove. I also checked and wires for continuity they are okay. According to what the paper work says it could be loose wires or a bad Electronic Oven Control unit. Should I replace the EOC unit, I ordered an EOC unit from your company today, am I correct in my assumption. Thanks Joe
