I have a temperature control problem with my older Hotpoint double oven. The right oven comes on, but the temperature cannot be controlled. When it is turned on BAKE, the temperature goes to 600 degrees no matter how low I set it. The temperature sensor ohmed out as bad, so I replaced it, but that did not fix the problem. Any suggestions greatly appreciated. -Mel
