woodman46
#1 Posted : Tuesday, September 9, 2014 10:50:18 AM(UTC)
woodman46
No model number. Unfortunately the previous owner scrubbed off the model number from the ID plate. This is a "plain vanilla" Magic Chef Gas Range, about 15 years old. Electronic ignition meaning glow wire for oven, spark igniters for burners. No electronic clock controls--only analog clock with timer.
The oven overheats by 50 degrees. Is there some way to adjust the oven temp? Or is the only solution to buy new oven control with new oven temp sensor?
#2 Posted : Wednesday, September 10, 2014 5:51:48 AM(UTC)
Perhaps the following will help
http://www.applianceaid.com/ele...ics.php#standard-control
take a look at "How to change a standard controlled oven temp:"
woodman46
#3 Posted : Wednesday, September 10, 2014 9:18:58 AM(UTC)
woodman46
Thanks much! Your're a lifesaver. I don't have the adjustable template on the back of the oven knob but I do have the hollow shaft with small screw at the bottom--size of screw on eye glasses. Turned left about 50 degrees. Will see what this brings in terms of temp reduction. I assume this is trial and error?
#4 Posted : Wednesday, September 10, 2014 9:33:42 AM(UTC)
woodman46
#5 Posted : Wednesday, September 10, 2014 12:53:00 PM(UTC)
woodman46
Yes, you were definitely able to help. I also learned that the small screw decreases temp when turned right and increases temp when turned left--same direction as the oven dial increases or decreases temp.
Whirlpool RBS305PDB1 wall oven temp control (Oven Repair (including Ranges and Cooktops))
by WPoven 3/28/2022 7:14:02 PM(UTC)
Westinghouse Oven Temp Control & Model Question (Oven Repair (including Ranges and Cooktops))
by Mark_in_Seattle 8/28/2010 12:05:47 PM(UTC)
by lewmerk 7/22/2010 1:36:22 PM(UTC)
Need new oven temp control (Oven Repair (including Ranges and Cooktops))
by WayneDeLisle 11/10/2009 9:27:11 AM(UTC)
Oven Temp Control Problem (Oven Repair (including Ranges and Cooktops))
by tfarrill 10/21/2009 6:50:30 PM(UTC)
Gas GE Oven temp control knob spinning? (Oven Repair (including Ranges and Cooktops))
by Hokies_fan 7/2/2009 4:24:21 PM(UTC)
Increase oven temp control not working (Oven Repair (including Ranges and Cooktops))
by fioman6740 4/25/2009 8:06:55 PM(UTC)
Whirlpool oven temp control (Oven Repair (including Ranges and Cooktops))
by olivia 10/28/2008 10:50:05 AM(UTC)
Oven temp control (Oven Repair (including Ranges and Cooktops))
by fred1329 9/15/2007 8:33:13 PM(UTC)
