| » Oven won't light |
Model Number: RGB740BEH3WH Brand: GE Age: 1 - 5 years
First my range had the electronic sparks would spark with everything turned off. So we replaced the spark modulator. Then the control board wouldn't come on so we replaced it. Now my oven won't come on. I have been trying to fine a wiring diagram for it so we can make sure we have the wires in the right place. Do you know where I can find one. I have contacted GE over a week ago and they still haven't emailed me one.
Quote:
Quote:
JMO Dan O. www.Appliance411.com The Appliance Information Site =D~~~~~~ |
GE is worthless!!!!!!!!!! Let me ask you this. You have a bake ignitor and a broiler ignitor. Check and see if either one comes on. If either one does not work, then it will be a control issue. It is a double gas valve, so it is highly unlikely that both sides of the valve are bad. Report back to me, if the either ignitor comes on, because it could just be an ignitor, or in the process of you replacing the control board, something could not be right there. Tom www.aplianceeducator.com
The broiler does light and come on. Now it sounds like one of the lighters is trying to light with nothing turned on. I'll get with ge again to see if they have found the diagram yet. Do you think that maybe the ignitor for the the oven has gone bad?
not sure if it is a top. About every thirty seconds you can hear a noise that sounds like one click. We put a new spark module in and it stoped for two days now it is back. We put a new control panel in and the lower part of oven is the only think that won't work. The broil and the self clean both come on but in self clean the lower part won't come on. The range doesn't give me any kind of code so I can look up that problem.
| Display Modes | |
| Oven burner wont light or takes a long time to light | shadyray | Oven Repair (including Ranges and Cooktops) | 4 | 01-30-2011 08:26 PM |
| Blinking Blue Lights (Oven ON Light & Oven Heating Light | bubbah2os | Oven Repair (including Ranges and Cooktops) | 1 | 02-05-2010 01:07 PM |
| kenmore oven will light, bring oven to temp, but won't re-light after the temp.... | weedsnager | Oven Repair (including Ranges and Cooktops) | 1 | 12-02-2009 05:28 PM |
| Oven doesn't light, Broil and Preheat will light | tisears | Oven Repair (including Ranges and Cooktops) | 1 | 09-09-2009 12:38 PM |
| magic chef propane oven won't light (has pilot light) | A and J | Oven Repair (including Ranges and Cooktops) | 3 | 09-19-2008 12:36 PM |
