My whirlpool oven burner will not come on. The ignitor glows, amps out at 2.8 amps & measures 120 ohms cold. The broiler works fine,its ignitor amps out at 3.3amps and measures 100 ohms cold. Just wondering if both ignitors are the same & maybe the oven ignitor is going bad. I don't know what the ohms or amp draw should be & don't want to buy a dual gas valve if it is just an ignitor issue. Any help would be appreciated. I will buy the ignitor and or dual gas valve if needed from you. Looking forward to your response.
Thanks Paul
