| » oven won't light |
Model Number: FGF326ASF Brand: Frigidaire Age: 5 - 10 years
I moved about 6 months ago from natural gas to propane. I changed orfices and adjusted the safety valve. The ignitor burns bright but the gas won't come on. I tap on the top of the safety valve and the burner will ignite. Oven would work fine. Now after preheating the oven won't come on unless you tap the safety valve again. Would the safety valve be bad or will the igniter be bad?
The problem with the oven is the ignitor. The ignitor is too weak to open the gas valve. So when you pop the gas valve, it opens, and then ignites. You need to replace the ignitor. The part # is 5303935066. Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
| Display Modes | |
| Oven burner wont light or takes a long time to light | shadyray | Oven Repair (including Ranges and Cooktops) | 4 | 01-30-2011 08:26 PM |
| Blinking Blue Lights (Oven ON Light & Oven Heating Light | bubbah2os | Oven Repair (including Ranges and Cooktops) | 1 | 02-05-2010 01:07 PM |
| kenmore oven will light, bring oven to temp, but won't re-light after the temp.... | weedsnager | Oven Repair (including Ranges and Cooktops) | 1 | 12-02-2009 05:28 PM |
| Oven doesn't light, Broil and Preheat will light | tisears | Oven Repair (including Ranges and Cooktops) | 1 | 09-09-2009 12:38 PM |
| magic chef propane oven won't light (has pilot light) | A and J | Oven Repair (including Ranges and Cooktops) | 3 | 09-19-2008 12:36 PM |
