Discuss
Oven won't light
 in
Hi, We have an old Magic Chef oven in our RV. It is at least 25 years old, but still
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven won't light
  #1 (permalink)
Old 09-29-2008, 12:25 PM
Junior Member
santabarnett is on a distinguished road
Default Oven won't light
Model Number: BT16KA-4TZ   Brand: Magic Chef   Age: More than 10 years
We have an old Magic Chef oven in our RV. It is at least 25 years old, but still in very good condition. The top burners light just fine as does the Oven Pilot light. However, the oven burner would not light. I assumed the oven burner valve was bad as it never seemed to open and allow gas to the burner even after the pilot had been on for a long time, so I replaced the oven burner valve. It still does not work. I did notice that when I put the Oven Thermostat dial in the Pilot postition, there is some gas going to the main burner side as well. It does not get to the burner because the burner valve will still not open. I opened the thermostat control valve, and it seems okay inside. No leaks after I put it together again. I cannot figure out if I got a bad part in the new oven burner valve, or if somehow the thermostat and it are connected and I don't know about it.
Ads By Google
Related Models
Magic Chef BT16KK-3 Rv Range - Gas
Magic Chef BT16KK-3S Rv Range - Gas
Magic Chef BT16KK-4 Rv Range - Gas
Magic Chef BT16KK-4S Rv Range - Gas
Magic Chef BT16KK-4ST Rv Range - Gas
Magic Chef BT16KK-4T Rv Range - Gas
Magic Chef BT16KN-3 Rv Range - Gas
Magic Chef BT16KN-3S Rv Range - Gas
Magic Chef BT16KN-4 Rv Range - Gas
Magic Chef BT16KN-4S Rv Range - Gas
Magic Chef BT16KN-4ST Rv Range - Gas
Magic Chef BT16KN-4T Rv Range - Gas
Magic Chef BT16KS-3 Rv Range - Gas
Magic Chef BT16KS-3S Rv Range - Gas
Magic Chef BT16KS-4 Rv Range - Gas
Magic Chef BT16KS-4S Rv Range - Gas
Magic Chef BT16KS-4ST Rv Range - Gas
Magic Chef BT16KS-4T Rv Range - Gas
Magic Chef BT16KY-4 Rv Range - Gas
Magic Chef BT16LA-3 Rv Range - Gas
Magic Chef BT16LA-3Z Rv Range - Gas
Magic Chef BT16LA-4 Rv Range - Gas
Magic Chef BT16LA-4T Rv Range - Gas
Magic Chef BT16LA-4TZ Rv Range - Gas
Magic Chef BT16LA-4Z Rv Range - Gas
Magic Chef BT16LK-3 Rv Range - Gas
Magic Chef BT16LK-3Z Rv Range - Gas
Magic Chef BT16LK-4 Rv Range - Gas
Magic Chef BT16LK-4T Rv Range - Gas
Magic Chef BT16LK-4TZ Rv Range - Gas
Magic Chef BT16LK-4Z Rv Range - Gas
Magic Chef BT16LN-3 Rv Range - Gas
Magic Chef BT16LN-3Z Rv Range - Gas
Magic Chef BT16LN-4 Rv Range - Gas
Magic Chef BT16LN-4T Rv Range - Gas
Magic Chef BT16LN-4TZ Rv Range - Gas
Magic Chef BT16LN-4Z Rv Range - Gas
Magic Chef BT16LS-3 Rv Range - Gas
Magic Chef BT16LS-3Z Rv Range - Gas
Magic Chef BT16LS-4 Rv Range - Gas
Magic Chef BT16LS-4T Rv Range - Gas
Magic Chef BT16LS-4TZ Rv Range - Gas
Magic Chef BT16LS-4Z Rv Range - Gas
Magic Chef BT16LY-3 Rv Range - Gas
Magic Chef BT16LY-4 Rv Range - Gas
Magic Chef BT16LY-4T Rv Range - Gas
Magic Chef BT16LY-4TZ Rv Range - Gas
Magic Chef BT16LY-4Z Rv Range - Gas
Magic Chef BT16MA-3 Rv Range - Gas
Magic Chef BT16MA-3T Rv Range - Gas
Magic Chef BT16MA-3Z Rv Range - Gas
Magic Chef BT16MA-4 Rv Range - Gas
Magic Chef BT16MA-4T Rv Range - Gas
Magic Chef BT16MA-4TZ Rv Range - Gas
Magic Chef BT16MA-4Z Rv Range - Gas
Magic Chef BT16MK-3 Rv Range - Gas
Magic Chef BT16MK-3T Rv Range - Gas
Magic Chef BT16MK-3Z Rv Range - Gas
Magic Chef BT16MK-4 Rv Range - Gas
Magic Chef BT16MK-4T Rv Range - Gas
Magic Chef BT16MK-4TZ Rv Range - Gas
Magic Chef BT16MK-4Z Rv Range - Gas
Magic Chef BT16MN-3 Rv Range - Gas
Magic Chef BT16MN-3T Rv Range - Gas
Magic Chef BT16MN-3Z Rv Range - Gas
Magic Chef BT16MN-4 Rv Range - Gas
Magic Chef BT16MN-4T Rv Range - Gas
Magic Chef BT16MN-4TZ Rv Range - Gas
Magic Chef BT16MN-4Z Rv Range - Gas
Magic Chef BT16MS-3 Rv Range - Gas
Magic Chef BT16MS-3T Rv Range - Gas
Magic Chef BT16MS-3Z Rv Range - Gas
Magic Chef BT16MS-4 Rv Range - Gas
Magic Chef BT16MS-4T Rv Range - Gas
Magic Chef BT16MS-4TZ Rv Range - Gas
Magic Chef BT16MS-4Z Rv Range - Gas
Magic Chef BT16MY-3 Rv Range - Gas
Magic Chef BT16MY-3T Rv Range - Gas
Magic Chef BT16MY-3Z Rv Range - Gas
Magic Chef BT16MY-4 Rv Range - Gas
Magic Chef BT16MY-4T Rv Range - Gas
Magic Chef BT16MY-4TZ Rv Range - Gas
Magic Chef BT16MY-4Z Rv Range - Gas
Magic Chef BT16NA-3 Rv Range - Gas
Magic Chef BT16NA-3T Rv Range - Gas
Magic Chef BT16NA-3Z Rv Range - Gas
Magic Chef BT16NA-4 Rv Range - Gas
Magic Chef BT16NA-4T Rv Range - Gas
Magic Chef BT16NA-4TZ Rv Range - Gas
Magic Chef BT16NA-4Z Rv Range - Gas
Magic Chef BT16NK-3 Rv Range - Gas
Magic Chef BT16NK-3T Rv Range - Gas
Magic Chef BT16NK-3Z Rv Range - Gas
Magic Chef BT16NK-4 Rv Range - Gas
Magic Chef BT16NK-4T Rv Range - Gas
Magic Chef BT16NK-4TZ Rv Range - Gas
Magic Chef BT16NK-4Z Rv Range - Gas
Magic Chef BT16NS-3 Rv Range - Gas
Magic Chef BT16NS-3T Rv Range - Gas
Magic Chef BT16NS-3Z Rv Range - Gas
Magic Chef BT16NS-4 Rv Range - Gas
Magic Chef BT16NS-4T Rv Range - Gas
Magic Chef BT16NS-4TZ Rv Range - Gas
Magic Chef BT16NS-4Z Rv Range - Gas
Magic Chef BT16P-4 Rv Range - Gas
Magic Chef BT16PA-3 Rv Range - Gas
Magic Chef BT16PA-4 Rv Range - Gas
Magic Chef BT16PA-4T Rv Range - Gas
Magic Chef BT16PA-4TZ Rv Range - Gas
Magic Chef BT16PA-4Z Rv Range - Gas
Magic Chef BT16PK-3 Rv Range - Gas
Magic Chef BT16PK-4 Rv Range - Gas
Magic Chef BT16PK-4T Rv Range - Gas
Magic Chef BT16PK-4TZ Rv Range - Gas
Magic Chef BT16PK-4Z Rv Range - Gas
Magic Chef BT16PN-3 Rv Range - Gas
Magic Chef BT16PN-4T Rv Range - Gas
Magic Chef BT16PS-4 Rv Range - Gas
Magic Chef BT16PS-4T Rv Range - Gas
Magic Chef BT16PS-4TZ Rv Range - Gas
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven burner wont light or takes a long time to light shadyray Oven Repair (including Ranges and Cooktops) 4 01-30-2011 08:26 PM
Blinking Blue Lights (Oven ON Light & Oven Heating Light bubbah2os Oven Repair (including Ranges and Cooktops) 1 02-05-2010 01:07 PM
kenmore oven will light, bring oven to temp, but won't re-light after the temp.... weedsnager Oven Repair (including Ranges and Cooktops) 1 12-02-2009 05:28 PM
Oven doesn't light, Broil and Preheat will light tisears Oven Repair (including Ranges and Cooktops) 1 09-09-2009 12:38 PM
magic chef propane oven won't light (has pilot light) A and J Oven Repair (including Ranges and Cooktops) 3 09-19-2008 12:36 PM
