Leslie McFarland
#1 Posted : Wednesday, July 14, 2010 3:58:56 PM(UTC)
Leslie McFarland
I have a built in oven and the controls are working fine...in fact it shows pre heated to what ever I select but the oven is cold. I noticed that this happened after I completed a self cleaning cycle. I have turned off the oven and back on to try and clear but no luck. Someone mentioned that their is a reset button on the controls. I've turned off the oven and opened the door and removed 4 small screws from just under the control panel but I can not figure out how to get the control panel cover off? Any suggestions are greatly appreciated!:)
Thanks, Leslie
Lower GE wall oven won't heat up (Oven Repair (including Ranges and Cooktops))
by scalpeldoc 2/6/2019 11:56:18 AM(UTC)
Samsung Range and Oven Won't Heat Up (Oven Repair (including Ranges and Cooktops))
by neweyess 8/19/2013 5:13:28 AM(UTC)
Kenmore gas oven won't heat up properly (Oven Repair (including Ranges and Cooktops))
by Black Cherry 3/27/2013 11:12:55 AM(UTC)
The oven won't heat up. The pilot is lit and not heating oven (Oven Repair (including Ranges and Cooktops))
by Hazelave.corp 11/21/2012 3:55:15 PM(UTC)
whirlpool oven won't heat up (Oven Repair (including Ranges and Cooktops))
by smeighan 11/19/2012 4:38:18 PM(UTC)
Oven won't heat up but broiler works fine (Oven Repair (including Ranges and Cooktops))
by NJ Mom of 3 11/11/2012 4:42:15 PM(UTC)
Oven won't heat up? element and/or sensor problem?? (Oven Repair (including Ranges and Cooktops))
by renzandjo 7/18/2012 9:26:23 AM(UTC)
kitchenaid oven won't heat up (Oven Repair (including Ranges and Cooktops))
by susanm 6/5/2012 6:29:46 AM(UTC)
Oven won't heat up after self cleaning cycle (Oven Repair (including Ranges and Cooktops))
by ToughTags 2/28/2012 3:15:55 PM(UTC)
Maytag Oven Won't heat up (Oven Repair (including Ranges and Cooktops))
by Petezr 1/25/2012 6:27:38 PM(UTC)
GE Wall Oven Won't heat up (Oven Repair (including Ranges and Cooktops))
by tejyam@hotmail.com 1/17/2012 1:29:54 PM(UTC)
Oven won't heat up, need help! (Oven Repair (including Ranges and Cooktops))
by dogrobber13 8/16/2011 8:09:08 AM(UTC)
by macnchez 7/5/2011 3:19:55 PM(UTC)
Oven won't heat up (Oven Repair (including Ranges and Cooktops))
by Haf 6/12/2011 3:27:40 PM(UTC)
Maytag Gas Oven Won't heat Up (Oven Repair (including Ranges and Cooktops))
by cjklein1 4/22/2011 10:01:07 AM(UTC)
