Discuss
Kitchenaid ice maker
 in
General Talk
I have a Kitchen Aid Ice Machine model# KUIS18NNJW4 that is giving me nothing but a fit. The problem is
Appliance Repair Forum > Appliance Repair Help > General Talk » Kitchenaid ice maker
  #1 (permalink)
Old 05-23-2008, 08:18 PM
bryan b bryan b is offline
Junior Member
bryan b is on a distinguished road
Default Kitchenaid ice maker
I have a Kitchen Aid Ice Machine model# KUIS18NNJW4 that is giving me nothing but a fit. The problem is while the machine is running and making ice after the cycle is over the pump will continue to run making a sound like it is sucking air. When you turn the machine off and back on it will start the samething over again. We had it checked and the repair man said it was the pump. So we replaced it and that didnt fix it. Next we were told to replace the circuit board that it wasnt giving the comand to the pump to turn off when there was no water. Replaced the circuit board and same problem exists. What can be done to fix it?
  #2 (permalink)
Old 05-23-2008, 11:06 PM
ApplianceJunk's Avatar
ApplianceJunk ApplianceJunk is offline
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
When was the last time you cleaned it?
What happens with these is the plate that freezes the water gets dirty.
Then the sheet of ice does not slide all the way off to the grid to be cut into cubes.
The sheet of ice makes a bridge between the plate that makes the ice and the grid that cuts the ice.
The water then starts to run accross this bridge of ice instead of through the pump like it should be and that is were you are getting the sucking sound.
I would read the instuctions for cleaning the ice maker and run a bottle or two of ice machine cleaner though it.
__________________
John Pahl
ApplianceJunk.com
ApplianceDigest.com
  #3 (permalink)
Old 08-04-2008, 06:56 PM
gregg gregg is offline
Junior Member
gregg is on a distinguished road
Default
I would replace the water inlet alve as it sounds like it is not working. I had the same problem and it is working fine.
  #4 (permalink)
Old 08-23-2008, 05:53 AM
mikemathew mikemathew is offline
Junior Member
mikemathew is on a distinguished road
Default kitchenaid cream maker Ice Cream Makers
Convert any Kitchen Aid stand mixer into an ice cream maker with this handy attachment, and you can make a homemade treat that's fresh and pure. Store the bowl in the freezer, follow directions and you'll soon be making up to two quarts of your favorite frozen dessert. The ice cream maker is designed to fit all Kitchen Aid household stand mixers.Convert any Kitchen Aid stand mixer into an ice cream maker with this handy attachment, and you can make a homemade treat that's fresh and pure. Store the bowl in the freezer, follow directions and you'll soon be making up to two quarts of your favorite frozen dessert. The ice cream maker is designed to fit all Kitchen Aid household stand mixers.
mikemathew
[URL="http://www.drugaddiction.net/mississippi"]Mississippi Drug Addiction[/URL]
  #5 (permalink)
Old 08-25-2008, 01:18 PM
jackmcmanus21 jackmcmanus21 is offline
Junior Member
jackmcmanus21 is on a distinguished road
Default
thanks for the tip Mike
  #6 (permalink)
Old 03-08-2009, 02:05 PM
mikew mikew is offline
Junior Member
mikew is on a distinguished road
Default Kitchen Aid Ice Maker Woes (model # KUIS155HB10)
Hello,
I am having a similar problem and have had for 5 yrs - that is how long I have lived in this house, the unit is 8.5 yrs old. It will make ice like no tomorrow for 6 months and then do what you are talking about. We have cleaned and cleaned - sometimes it works and sometimes you just turn it off and on, over and over again and it will usually work - sometimes this takes a few weeks
This time however, the tank seems to be low on water, the pump 'chugs' and the ice that is formed does not drop off of the plate, it will only make ice on the initial startup. Today I have confirmed that all of the devices work with the test equipment available to me.
Did you change the supply water valve as was recommended?? If so, did that fix your issue?? Any help would be appreciated
[quote=bryan b;22465]I have a Kitchen Aid Ice Machine model# KUIS18NNJW4 that is giving me nothing but a fit. The problem is while the machine is running and making ice after the cycle is over the pump will continue to run making a sound like it is sucking air. When you turn the machine off and back on it will start the samething over again. We had it checked and the repair man said it was the pump. So we replaced it and that didnt fix it. Next we were told to replace the circuit board that it wasnt giving the comand to the pump to turn off when there was no water. Replaced the circuit board and same problem exists. What can be done to fix it?[/quote]
  #7 (permalink)
Old 03-08-2009, 08:30 PM
Junior Member
Default
Mike, these things can be tricky and aggravating. the water inlet valve was the answer for mine. They get dirty and do not work properly. If the pump is sucking air then it is not getting water. The water valve cost a lot less than the circuit board and the pump.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is Off
Smilies are On
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchenaid Refrigerator vmill63 Refrigerator & Freezer Repair 6 03-02-2009 05:41 PM
Kitchenaid Icemaker DFINLEY Refrigerator & Freezer Repair 0 04-27-2008 11:19 AM
Kitchenaid Stove F2 shuditstayorgo Oven Repair (including Ranges and Cooktops) 1 03-04-2008 04:11 PM
Ice maker issues Kitchenaid pezley69 Refrigerator & Freezer Repair 9 01-09-2008 01:15 PM
kitchenaid icemaker matthew Refrigerator & Freezer Repair 1 09-02-2007 11:40 AM
