mjlj
#1 Posted : Monday, July 6, 2015 8:18:13 AM(UTC)
mjlj
Greetings, I have a Maytag Atlantis. The timer is not advancing in either the auto nor timed modes. I replaced the timer and it does not advance either. I double checked all the connections for connectivity and placement and they are all good. I cleaned the moisture sensor and while I am getting a good reading from the moisture monitor, the timer is still not advancing in auto mode.
What is my next step? I have read a few forums and I am not getting very good direction.
Any help would be greatly appreciated!
fairbank56
#2 Posted : Monday, July 6, 2015 8:56:22 AM(UTC)
fairbank56
Groups: Expert
Sounds like a faulty dryness board. Part is no longer available from us or the manufacturer but you might find it somewhere. Search on part number 33002400. You can try unplugging the board and cleaning the board contacts and the connector contacts. If that doesn't work, leave it unplugged and jump the red and brown wires. This will allow the timer to work in timed dry only.
Eric
mjlj
#3 Posted : Monday, July 6, 2015 9:55:39 AM(UTC)
mjlj
Hi Eric, Thank you for your responce. Would the "dryness board" you are refering to, be called the Electronic Dry Control on my Electrical Wiring Diagram?
mjlj
#4 Posted : Monday, July 6, 2015 10:24:59 AM(UTC)
mjlj
Ok, I took another step and as per your instructions by "If that doesn't work, leave it unplugged and jump the red and brown wires. This will allow the timer to work in timed dry only." The timer does works in timed mode however it does not turn off when complete, it only rings the finish bell.
fairbank56
#5 Posted : Monday, July 6, 2015 12:45:09 PM(UTC)
fairbank56
Groups: Expert
I'm confused. Timer works in timed dry normally or only when you jump the two wires? Dryer doesn't stop when timer gets into OFF position? Continues through OFF and into next cycle?
Eric
Electric dryer, timer not advancing in auto mode (Dryer Repair)
by joet60 1/29/2017 7:20:59 AM(UTC)
Whirlpool Dryer Timer not advancing (Dryer Repair)
by jconkl02 5/9/2016 9:47:22 AM(UTC)
Kenmore washer timer not advancing (Washer Repair)
by sherlockbill 9/7/2015 9:37:23 PM(UTC)
No heat, timer not advancing on autosense (Dryer Repair)
by fgaggia 9/5/2014 12:48:30 PM(UTC)
Maytag MDE7658BYW Timer not advancing/dryer will not shut off (Dryer Repair)
by countrybois 6/13/2014 10:47:30 AM(UTC)
Frigidare stackable timer not advancing (Washer Repair)
by aford89 3/12/2014 8:06:17 AM(UTC)
Maytag Gas Dryer Timer not Advancing = Clothes not Drying (Dryer Repair)
by troxel 3/4/2014 6:43:42 AM(UTC)
timer not advancing and no heat (Dryer Repair)
by elymoe 1/12/2014 8:44:11 AM(UTC)
Timer not advancing, but the timer is good. (Dryer Repair)
by skylux 12/17/2013 12:42:42 AM(UTC)
Roper dryer not heating and timer not advancing (Dryer Repair)
by kennethgore 12/2/2013 7:09:15 AM(UTC)
Timer not advancing (Washer Repair)
by andyvh1959 4/17/2013 7:33:49 PM(UTC)
Roper Dryer Auto timer not advancing (Dryer Repair)
by Cheryl_A 9/14/2012 7:50:11 AM(UTC)
by Ehoff 8/30/2012 11:15:28 AM(UTC)
Whirlpool dryer not heating timer not advancing (Dryer Repair)
by mbell418 7/13/2011 8:39:30 AM(UTC)
by msbee03 6/9/2011 12:09:03 PM(UTC)
