franzy365
#1 Posted : Thursday, January 2, 2014 4:45:23 PM(UTC)
franzy365
thermal mounted to heat element bracket reads thru (0 ohms). lifted one lead on element and my reading was about 40 ohms. wondering what that reading should be. was hoping for an open to make it easy...no such luck. would appreciate any tips you could give.
fairbank56
#2 Posted : Thursday, January 2, 2014 6:54:06 PM(UTC)
fairbank56
Groups: Expert
Can't find wiring diagram for this one. If you can provide clear photo of wiring diagram, then I can help you. Should be inside cabinet somewhere.
Eric
#3 Posted : Friday, January 3, 2014 2:50:29 AM(UTC)
Parts for Whirlpool KEYS850JQ1 Dryer - AppliancePartsPros.com
See the attachment for the wiring diagram.
Looks like this is a dual element heater.
Each element should be about 20 ohms.
So if you measured the two elements in series 20 ohms would be OK.
The first thing to check when there is no heat is the power.
The motor and timer run off of half the line (120 volts) but the heater requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
If the power is good then unplug the unit and set the unit to the setting where you get no heat. Use a high heat setting.
Set your meter to it's most sensitive scale (usually 200 ohms) and short the meter leads together before starting to see if there is a zero offset in the meter.
Attach your meter lead to L1 on the power cord and leave it there.
Now work your way back through the heater circuit.
So R on the timer should be 0 ohms.
Both sides of the Thermal Cutoff, Operating Thermostat and Hi-limit Thermostat should be 0 ohms.
The right hand side (on the wiring diagram) of the heater should be about 10 ohms.
Then check the temperature switches SH1 and SL0 see the timing/switching chart.
File Attachment(s):
KEYS850.pdf (192kb) downloaded 2 time(s).
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag 1/5/2024 1:41:07 PM(UTC)
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam 11/2/2023 10:52:15 AM(UTC)
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 10/19/2023 4:56:37 PM(UTC)
No heat when assembled (Dryer Repair)
by Guest 8/16/2023 3:44:03 AM(UTC)
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
by Guest 7/13/2023 12:27:07 PM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
No heat, (Dryer Repair)
by tseibring 1/8/2023 7:57:44 AM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 7/5/2022 6:35:29 PM(UTC)
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 6/28/2022 11:03:33 AM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 2/6/2022 2:57:49 PM(UTC)
LG Gas Dryer No Heat - Control Panel? (Dryer Repair)
by TomDBBills 1/29/2022 4:03:42 PM(UTC)
