Discuss
Dryer Repair
 in
Dryer Repair
Hello Friends, Thank you for coming in this thread. There is a QUESTION for you. Dryer repair question? I have
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer Repair
  #1 (permalink)
Old 09-08-2013, 10:47 PM
Junior Member
fredpeterson543 is on a distinguished road
Default Dryer Repair
Model Number: ALL   Brand: Amana   Age: 1 - 5 years
Hello Friends,
I have a 2 year old dryer that I turned on one day and it immediately stopped after 5 seconds. I cannot start it by turning the switch but I can start it by hand by spinning the drum with the door button pushed down (it works I swear). Once I get it running by hand it still does not produce heat.
It is not a fuse or outlet problem because it can still run.
Does anyone have any idea of what part needs to be replaced? I think it might just need a new switch because it not only starts the drum but it also turns on the heating element. This would explain why it does not heat up when I get it going by hand.
Web Designing Companies in Delhi
Related Models
General Electric ALM15DAM1 Room air conditioner
General Electric ALM18DAM1 Zoneline
Admiral ALR1100AJQ RANGE- F/S STD GAS
Admiral ALR1100AJW RANGE- F/S STD GAS
Admiral ALR1420BDQ RANGE- F/S STD GAS
Admiral ALR1420BDW RANGE- F/S STD GAS
Admiral ALR1450AJW RANGE- F/S STD GAS
Admiral ALR1450BJW RANGE- F/S STD GAS
Admiral ALR5715QDS RANGE- S/C F/S GAS
Admiral ALR5715QDW RANGE- S/C F/S GAS
Amana ALW110RAW WASHER-TOP LOADING
Amana ALW210RAW WASHER-TOP LOADING
Amana ALW210RMC Washer - Top Loading
Amana ALW210RMC WASHER-TOP LOADING
Amana ALW210RMW Washer - Top Loading
Amana ALW210RMW WASHER-TOP LOADING
Admiral ALW221RJW WASHER-TOP LOADING
Amana ALW410DAW WASHER-TOP LOADING
Amana ALW430RAC WASHER-TOP LOADING
Amana ALW430RAW WASHER-TOP LOADING
Amana ALW432RAW WASHER-TOP LOADING
Amana ALW450QAC WASHER-TOP LOADING
Amana ALW450QAW WASHER-TOP LOADING
Amana ALW480DAC WASHER-TOP LOADING
Amana ALW480DAW WASHER-TOP LOADING
Amana ALW540RAC WASHER-TOP LOADING
Amana ALW540RAW WASHER-TOP LOADING
Amana ALW540RMC Washer - Top Loading
Amana ALW540RMC WASHER-TOP LOADING
Amana ALW540RMW Washer - Top Loading
Amana ALW540RMW WASHER-TOP LOADING
Amana ALW680RAC WASHER-TOP LOADING
Amana ALW680RAW WASHER-TOP LOADING
Amana ALW780QAC WASHER-TOP LOADING
Amana ALW780QAW WASHER-TOP LOADING
Amana ALW780QMC Washer - Top Loading
Amana ALW780QMC WASHER-TOP LOADING
Amana ALW780QMW Washer - Top Loading
Amana ALW780QMW WASHER-TOP LOADING
Amana ALW880QAC WASHER-TOP LOADING
Amana ALW880QAC1 WASHER-TOP LOADING
Amana ALW880QAW WASHER-TOP LOADING
Amana ALW880QAW1 WASHER-TOP LOADING
Amana ALW891SAW WASHER-TOP LOADING
Amana ALW895SAC WASHER-TOP LOADING
Amana ALW895SAW WASHER-TOP LOADING
Amana ALW990EAC WASHER-TOP LOADING
Amana ALW990EAW WASHER-TOP LOADING
General Electric ALX12AAM1 Room air conditioner
General Electric ALX12DAM1 Room air conditioner
General Electric ALX14AAM1 Room air conditioner
General Electric ALX15DAM1 Room air conditioner
Amana ALY1680ADB RV RANGE- GAS
Amana ALY1680ADQ RV RANGE- GAS
Amana ALY1680ADS RV RANGE- GAS
Amana ALY1680ADW RV RANGE- GAS
Amana ALY1680BDB RV RANGE- GAS
Amana ALY1680BDS RV RANGE- GAS
Amana ALY2280ADB RV RANGE- GAS
Amana ALY2280ADQ RV RANGE- GAS
Amana ALY2280ADS RV RANGE- GAS
Amana ALY2280ADW RV RANGE- GAS
Amana ALY2280BDB RV RANGE- GAS
Maytag ALY2280BDB12 22" GAS RV RANGE SEALED BURNERS
Amana ALY2280BDS RV RANGE- GAS
Maytag ALY2280BDS12 22" GAS RV RANGE SEALED BURNERS
Amana ALY2289ADB RV RANGE- GAS
Amana ALY2289BDB RV RANGE- GAS
Amana ALZ8580ADB RV SURFACE UNIT- GAS
Maytag ALZ8580ADB14 22" GAS RV COOKTOP SEALED BURNERS
Amana ALZ8580ADQ RV SURFACE UNIT- GAS
Amana ALZ8580ADS RV SURFACE UNIT- GAS
Maytag ALZ8580ADS14 22" GAS RV COOKTOP SEALED BURNERS
Amana ALZ8580ADW RV SURFACE UNIT- GAS
Amana ALZ8589ADB RV SURFACE UNIT- GAS
Amana ALZ8590ADB RV SURFACE UNIT- GAS
Amana ALZ8590ADS RV SURFACE UNIT- GAS
Bosch AM040-00
Frigidaire AM08B4ERBA Gib(v2) / Room Air Conditioner
Frigidaire AM08B4ESBA Gib(v1) / Room Air Conditioner
Frigidaire AM08B5EVA Gib(v1) / Room Air Conditioner
Frigidaire AM08B6ESBA Gib(v2) / Room Air Conditioner
Frigidaire AM08B6ESBB Gib(v1) / Room Air Conditioner
Frigidaire AM09C4EYA Gib(v1) / Room Air Conditioner
Frigidaire AM09C4EZA Gib(v1) / Room Air Conditioner
Frigidaire AM09C5EWA Gib(v1) / Room Air Conditioner
Frigidaire AM09C5EWB Gib(v1) / Room Air Conditioner
Frigidaire AM09C6EVA Gib(v1) / Room Air Conditioner
Frigidaire AM09C6EVA1 Gib(v1) / Room Air Conditioner
Frigidaire AM10C4ERBA Gib(v1) / Room Air Conditioner
Frigidaire AM10C4ESBA Gib(v3) / Room Air Conditioner
Frigidaire AM10C4ESBB Gib(v4) / Room Air Conditioner
Frigidaire AM10C4ETBA Gib(v1) / Room Air Conditioner
Frigidaire AM10C5EYA Gib(v1) / Room Air Conditioner
  #2 (permalink)
Old 09-09-2013, 02:21 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
I agree with you that it could be the centrifugal switches on the motor.
One thing to check is that the motor is not clogged solid with lint.
This can stop the mechanical device in the motor from activating the switches.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer Repair, Blower Wheel for dryer Darleneg2 Dryer Repair 3 01-16-2012 06:00 AM
dryer repair kit pascarella Dryer Repair 1 12-13-2010 07:10 AM
washer and dryer stack unit dryer repair drvarga Dryer Repair 0 11-18-2010 03:12 PM
Dryer Repair EES Dryer Repair 3 02-26-2009 06:54 AM
Dryer repair fairfieldfalcons Dryer Repair 0 01-19-2008 02:22 PM
