Discuss
Maytag dryer
 in
Dryer Repair
I have a Maytag Performa dryer, the dryer was running and suddenly stopped and there was a burning smell, I
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag dryer
  #1 (permalink)
Old 02-20-2013, 08:19 AM
Junior Member
Steve McAndrew is on a distinguished road
Default Maytag dryer
Model Number: pye2200ayw   Brand: Maytag   Age: 5 - 10 years
I have a Maytag Performa dryer, the dryer was running and suddenly stopped and there was a burning smell, I changed the heating element and the thermal fuse with no luck. Whats next. Thanks
Ads By Google
Related Models
Maytag PYE2200AYW DRYER- ELE
Maytag PYE2200AZW DRYER- ELE
Maytag PYE2300AYW DRYER- ELE
Maytag PYE2300AZW DRYER- ELE
Admiral PYE3200AGW DRYER- ELE
Maytag PYE3200AYW DRYER- ELE
Maytag PYE3200AZW DRYER- ELE
Admiral PYE3300AGW DRYER- ELE
Admiral PYE3300AKW DRYER- ELE
Maytag PYE3300AYW DRYER- ELE
Maytag PYE3300AZW DRYER- ELE
Maytag PYE3360AYW DRYER- ELE
Maytag PYE4500AYQ DRYER- ELE
Maytag PYE4500AYW DRYER- ELE
Maytag PYE4500AZW DRYER- ELE
Maytag PYE4557AYW DRYER- ELE
Maytag PYE4558AYW DRYER- ELE
Maytag PYET244AYW DRYER- ELE
Maytag PYET244AZW DRYER- ELE
Maytag PYET344AYW DRYER- ELE
Maytag PYET344AZW DRYER- ELE
Maytag PYET444AYW DRYER- ELE
Maytag PYET444AZW DRYER- ELE
Maytag PYG1000AWW DRYER- GAS
Maytag PYG2000AWW DRYER- GAS
Maytag PYG2200AWW DRYER- GAS
Admiral PYG2300AGW DRYER- GAS
Maytag PYG2300AWW DRYER- GAS
Maytag PYG3200AWW DRYER- GAS
Maytag PYG3250AWW DRYER- GAS
Maytag PYG3300AWW DRYER- GAS
Maytag PYG3360AWW DRYER- GAS
Maytag PYG4500AWQ DRYER- GAS
Maytag PYG4500AWW DRYER- GAS
Maytag PYG4557AWW DRYER- GAS
Maytag PYG4558AWW DRYER- GAS
Admiral PYGS244AWW DRYER- GAS
Maytag PYGT244AWW DRYER- GAS
Maytag PYGT344AWW DRYER- GAS
Maytag PYGT444AWW DRYER- GAS
Amana QDO-695 RANGE- S/C S/I DDRAFT GAS
Amana QDO-695D RANGE- S/C S/I DDRAFT GAS
Amana QDO-695E RANGE- S/C S/I DDRAFT GAS
Amana QDO-695F RANGE- S/C S/I DDRAFT GAS
Amana QDO-695G RANGE- S/C S/I DDRAFT GAS
Amana QDO-695H RANGE- S/C S/I DDRAFT GAS
Amana QDU-838 RANGE- S/C S/I DDRAFT GAS
Amana QDU-858 RANGE- S/C S/I DDRAFT GAS
Amana QDU-878 RANGE- S/C S/I DDRAFT GAS
Amana QDU-966 RANGE- S/C S/I DDRAFT GAS
Amana QDU-976 RANGE- S/C S/I DDRAFT GAS
Amana QKO-661 RANGE- S/C S/I DDRAFT GAS
Amana QKO-661B RANGE- S/C S/I DDRAFT GAS
Amana QKO-661C RANGE- S/C S/I DDRAFT GAS
Amana QKO-661D RANGE- S/C S/I DDRAFT GAS
Amana QKO-661E RANGE- S/C S/I DDRAFT GAS
Amana QKO-751 RANGE- S/C S/I DDRAFT GAS
Amana QKO-751A RANGE- S/C S/I DDRAFT GAS
Amana QKU-647 RANGE- S/C S/I DDRAFT GAS
Amana QKU-647A RANGE- S/C S/I DDRAFT GAS
Amana QMC811 WALLOVEN- STD MWAVE ELE
Amana QMD-800 MWAVE - FAMILY SIZE (60 HZ)
Amana QMD-800D MWAVE - FAMILY SIZE (60 HZ)
Amana QMD-800E MWAVE - FAMILY SIZE (60 HZ)
Amana QMD-810 MWAVE - FAMILY SIZE (60 HZ)
Amana QMD800 WALLOVEN- STD MWAVE ELE
Amana QMD800D MWAVE - FAMILY SIZE (60 HZ)
Amana QMD810 WALLOVEN- STD MWAVE ELE
Amana R-1 RANGE- S/C S/I DDRAFT GAS
Amana R-1H RANGE- S/C S/I DDRAFT GAS
Amana R-1J RANGE- S/C S/I DDRAFT GAS
Amana R-1J MWAVE - FAMILY SIZE (60 HZ)
Amana R-2 RANGE- S/C S/I DDRAFT GAS
Amana R-3 RANGE- S/C S/I DDRAFT GAS
Amana R-3 MWAVE - FAMILY SIZE (60 HZ)
Amana R0-24-8 MWAVE - FAMILY SIZE (60 HZ)
Amana R0-24-8 MWAVE- MOUNTED OVER RANGE/WO
Whirlpool R101 Air-conditioner/heat pump
Whirlpool R1011 Air-conditioner/heat pump
Whirlpool R1012 Air-conditioner/heat pump
Whirlpool R1013 AIR CONDITIONER
Whirlpool R1014 AIR CONDITIONER
Whirlpool R121 Air-conditioner/heat pump
Whirlpool R1211 Air-conditioner/heat pump
Whirlpool R1212 AIR CONDITIONER
Whirlpool R1213 AIR CONDITIONER
Whirlpool R1231 Air-conditioner/heat pump
 R1404 Air Conditioner
Whirlpool R141A AIR CONDITIONER
Whirlpool R141A1 AIR CONDITIONER
Whirlpool R141F0 AIR CONDITIONER
Whirlpool R141G0 AIR CONDITIONER
Amana R15 MISC / ACCESSORY
Whirlpool R153 Air-conditioner/heat pump
Amana R15A MISC / ACCESSORY
Amana R15L MISC / ACCESSORY
Amana R15LA MISC / ACCESSORY
Whirlpool R183 AIR CONDITIONER
Whirlpool R183A AIR CONDITIONER
Whirlpool R183A1 AIR CONDITIONER
Whirlpool R183A2 AIR CONDITIONER
Whirlpool R183A3 AIR CONDITIONER
Whirlpool R183F0 AIR CONDITIONER
Whirlpool R183G0 AIR CONDITIONER
Whirlpool R183G1 AIR CONDITIONER
Amana R1E MWAVE - FAMILY SIZE (60 HZ)
Jenn-Air R200 SURFACE UNIT- DDRAFT ELE
Frigidaire R2000DL0 Frg(v1) / Electric Range
Frigidaire R2000DW0 Frg(v2) / Electric Range
Frigidaire R2000LL1 Frg(v1) / Electric Range
Frigidaire R2000LW1 Frg(v2) / Electric Range
Jenn-Air R201 SURFACE UNIT- DDRAFT ELE
Jenn-Air R201-C SURFACE UNIT- DDRAFT ELE
Frigidaire R21CL0 Frg(v1) / Free Standing Electric Range
Frigidaire R21CL1 Frg(v1) / Free Standing Electric Range
Frigidaire R21CL2 Frg(v2) / Electric Range
  #2 (permalink)
Old 02-20-2013, 03:32 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
First of all check if there is 240VAC at the dryer's disconnect block at the back, be careful if you don't feel comfortable to work with "hot" appliance just try to reset the circuit breaker.
With unit unplugged:
Next, check the door switch for continuity between two contacts with wires on them (remove one wire off when checking).
You should read continuity with door closed and infinity with door open.
The switch Part number: 53-0148
Switch is good? Next check continuity at the motor contacts between PURPLE and WHITE. No continuity - replace the motor Part number: W10410996
If both above mentioned parts are good - replace the timer
Part number: 53-1810
Here are the breakdown diagrams and 05-Motor & Drive parts for Maytag PYE2200AYW - AppliancePartsPros.com
Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Dryer hayhunter8 Dryer Repair 11 02-20-2013 08:56 AM
Maytag Dryer Markneedshelp Dryer Repair 3 09-19-2012 12:15 PM
How do you open up the Maytag Electric Dryer cabinet to get to the dryer drum belt? Darrel Hedman Dryer Repair 1 05-13-2011 06:18 PM
Maytag Dryer dareynoldssr Dryer Repair 1 12-29-2010 05:32 PM
Maytag Gas Dryer lloydrealestate Dryer Repair 3 11-01-2010 08:32 AM
