aromero
#1 Posted : Monday, April 6, 2009 9:25:00 AM(UTC)
aromero
The display windows shows message error of "E68". Is this the display board or the interface board that needs replacing? Or is this the same item? The display board continually beeps and changes settings when not in use. Also, when you try to use the dryer, it doesn't always allow you to choose the setting you want. Then, it may or may not dry the clothes, often kicking off within 30 seconds of turning it on. Please advise.
#2 Posted : Monday, April 6, 2009 12:58:16 PM(UTC)
Here is the parts breakdown
Replacement parts for FRG AEQ6000ES1 | AppliancePartsPros.com
Here is a tech sheet
ftp://ftp.electrolux-na.com/Pr...r/134682200ts_wd_EFS.pdf
First unplug the unit to see if it will reset.
Next run the diagnostics.
Frigidaire Front Load Dryer aeq6000es2 (Dryer Repair)
by Guest 3/3/2024 7:28:15 AM(UTC)
LG/Kenmore Front Load Dryer -Model # 796.8178 (Dryer Repair)
by MDavis444 2/17/2024 5:47:52 PM(UTC)
Front load dryer problem (Dryer Repair)
by Guest 4/29/2021 5:08:47 AM(UTC)
Front (under door) of Electric GE Front Load Dryer Hot to Touch (Dryer Repair)
Belarus DryerDays 12/30/2016 2:33:53 PM(UTC)
Timer stopped working on Samsung front load dryer (Washer Repair)
by Mwgo 1/13/2015 8:24:22 PM(UTC)
GE front load dryer (Dryer Repair)
by Mcopenhaver 1/15/2014 9:03:16 AM(UTC)
Kenmore HE4 Front load Dryer wont Run (Dryer Repair)
by hunterhutch 12/23/2013 6:19:04 AM(UTC)
LG Tromm Front Load Dryer will not start (Dryer Repair)
by techiegirl 11/25/2013 5:37:56 PM(UTC)
Duet front load dryer no power on (Dryer Repair)
by Shorty@lamar 7/23/2013 5:52:41 PM(UTC)
Frigidaire Front Load Dryer Blinks E68 on LED (Dryer Repair)
by Cory Person 9/12/2012 7:18:54 AM(UTC)
Ge Front Load Dryer Will Not Dry Clothes (Dryer Repair)
by Tiff 7/10/2012 6:06:35 PM(UTC)
Help! My whirlpool duet front load dryer stuck in sensor mode! (Dryer Repair)
by Sandy DiMascolo 2/26/2012 1:25:34 PM(UTC)
Front load dryer not drying properly (Dryer Repair)
by jtalley007 8/24/2011 7:50:24 AM(UTC)
Whirlpool Duet front load dryer will not start (Dryer Repair)
by brokend 7/15/2011 9:48:14 AM(UTC)
Lg Front Load Dryer (Dryer Repair)
by eugene413 2/24/2011 4:56:14 PM(UTC)
