My dryer runs but does not heat. Runs for about 10 mins. then stops and all the lights blink. No error msg. Please tell me what all I need to meter and what their readings should be.
thanks
That info is on the tech sheet which you can find by removing the rear service panel. You should be able to get some error codes, and focus on testing the motor which sounds like it is failing. Try cleaning out everything first, including the air through the door if it goes that way.
