Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Samsung dryer Heating element continuity and ohm readings were good safety switches read good at 1 point I have 240 going to the element through the centrifucal switch in the motor to the element. When ran and shut off and turn back on about 3 hours later I had no heat and was only getting 134 V to the heating element Is this the control board?
Rank: Guest
Oh by the way unplug it let it sit for a few minutes plug it back in it works
