Dryer runs but no heat. Timer won't run on Cotton and Easycare cycles, but does run on the "Cool-Down" part of these cycles. Timer motor runs on "Timed Dry" cycle. Checked circiuts behind control panel with volt and ohm meter...seems to be OK. What is best the way to get to heaters and thermal interlocks for checking without disassembling everything?
