I replaced a overflow pressure relief valve on my water heater and my wife was still running the dishwasher while the supply was off. i know i know lol. i turned the water back on noticed it was making a different noise but didn't pay it much attention. next day i went to unload and there was water in the bottom i tried to turn it back to run a drain cycle, the unit wouldn't even turn on. I pulled the front cover and the electronic control box and noticed it was burnt up. now my question did it burn up because the pump froze should i order the electronic control box and pump W10461371 and the pump and motor assembly W10300740 if anyone has any other ideas please share as of now thats what I'm thinking happened correct me if I'm wrong backwoodsbubba86 attached the following image(s):
