Neiderhiserm
#1 Posted : Thursday, February 6, 2014 2:29:59 PM(UTC)
Neiderhiserm
it is leaking right above the transmission. i am assuming it is the seal but am having trouble removing the inner tub. UserPostedImage UserPostedImage UserPostedImage
I have removed 5 bolts from the bottom of the tub and am not sure what else i need to remove. any help would be greatly appreciated.
fairbank56
#2 Posted : Thursday, February 6, 2014 4:20:00 PM(UTC)
fairbank56
Groups: Expert
There is nothing else to remove to get the inner basket out. It is just stuck to the trunnion. That trunnion is in sad shape and you will have to chisel the lock plate off of it to get it off the spin tube to access the water seal underneath of it.
Eric
GSD5120D00BB GE dishwasher leaking at the bottom corners (Dishwasher Repair)
by ron Minervino 12/7/2023 9:15:11 AM(UTC)
Dishwasher Leaking Kitchenaid KDTE334DSS0 (Dishwasher Repair)
by Bscott46 10/4/2022 5:16:08 PM(UTC)
Old Maytag 712 Washer Leaking at Injector Valve (Washer Repair)
by ronp99 9/11/2022 1:40:40 PM(UTC)
Maytag top load washer leaking oil from transmission (Washer Repair)
by Rdchapman2 2/27/2022 1:15:02 PM(UTC)
Maytag dishwasher leaking and smoking (Dishwasher Repair)
by Guest 10/19/2021 2:58:51 PM(UTC)
LG Dishwasher Leaking When First Turned On (Dishwasher Repair)
by artriumph 4/22/2021 1:13:56 PM(UTC)
Kenmore Washer leaking ONLY Hot water during Fill (Washer Repair)
by colbey 1/11/2020 1:28:22 AM(UTC)
Maytag Dishwasher LEAKING underneath (Dishwasher Repair)
by bakerid2000 9/5/2019 5:49:20 PM(UTC)
Whirlpool dishwasher leaking bottom (Dishwasher Repair)
by nkaufman1 5/14/2019 1:50:41 AM(UTC)
Whirlpool washer leaking and won't fill with water (Washer Repair)
by christyhecht 6/16/2018 8:21:00 AM(UTC)
Bosch Dishwasher Leaking into base (Dishwasher Repair)
by Canadianice 4/12/2018 8:18:35 AM(UTC)
Dishwasher leaking underneath [PHOTOS] (Dishwasher Repair)
by jd514 1/6/2018 11:16:52 AM(UTC)
Bosch Nexxt 500 Series Washer leaking (Washer Repair)
by neustkg 9/21/2017 2:46:15 PM(UTC)
Kenmore Series 80 washer leaking water above clutch assembly (Washer Repair)
by hallway 2/5/2017 1:48:24 PM(UTC)
Kitchenaid dishwasher leaking under door (Dishwasher Repair)
by chasethedream 1/1/2017 8:30:50 AM(UTC)
