it is leaking right above the transmission. i am assuming it is the seal but am having trouble removing the inner tub. ![UserPostedImage](http://i1310.photobucket.com/albums/s650/Mitchell_Neiderhiser/BD33292C-9F1E-4070-ADFE-E52A4F919B9E-5237-000009A98A9BA3AD_zps5bfdefb2.jpg) I have removed 5 bolts from the bottom of the tub and am not sure what else i need to remove. any help would be greatly appreciated.
Groups: Expert
There is nothing else to remove to get the inner basket out. It is just stuck to the trunnion. That trunnion is in sad shape and you will have to chisel the lock plate off of it to get it off the spin tube to access the water seal underneath of it.
Eric
